I occasionally will get a clog in my evaporator line even though I pour bleach down it 2x a year. Is it legal or code approved for me to cut out a 2- 4 inch section of the pipe which is 1 inch PVC and use screw on PVC compression fitting or perhaps use rubber tubing with screw tightened clamps on the end?
This is a residential house with your normal slow-flowing evaporator condensation line to the outside.
The reason for this is so that I can then better get to any clogs with an auger. I cannot do so now since the PVC pipe connects through a P-trap to the HVAC unit and there are no removable sections.
Thank you very much
Peter in North Carolina
