Help with Moisture Meter Selection
Hi, new home inspector here. I am trying to a good moisture meter. I currently got the Tramez MRH III and while it is pretty spiffy, when I take drywall readings it seems to show a higher moisture content that when I do wood (usually in the 30 - 50 % range). I am looking for something that is simple and will give me a warning if an area is too moist.
Thanks,
Tim
Home Inspection Geeks
https://www.nachi.org/forum/f60/whats-consensus-moisture-meters-112608/
Check out Wagner Meters new Orion moisture meter. You can set a programmable alarm to beep when the moisture hits a certain percentage. It’s great!
https://www.wagnermeters.com/moisture-meters/
