Old 7/29/15, 12:06 PM
Joshua L. Frederick Joshua L. Frederick is online now
Lightbulb INachi graphic request thread
CSST bushing/grommet graphic as mentioned here: https://www.nachi.org/forum/f2/corrug...rommet-103538/
Also, a water softener improperly tapped into sanitary drain one would be great along with one that shows the proper way to do it (with an air gap, trap, etc.)
A house wrap picture would be swell, as well
Thanks in advance.
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/29/15, 7:28 PM
Daniel G. Desiga's Avatar
Daniel G. Desiga Daniel G. Desiga is offline
Default Re: INachi graphic request thread
Can this image get an update? It's hard to read. It can be found on the How to Inspect for Moisture Intrusion course. Thank you
This one too.
http://education.nachi.org/coursemed...5_flashing.jpg
Old 7/29/15, 7:31 PM
AC condensate trap graphic also would be nice..
Old 7/29/15, 7:39 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Would this work for you? Easy enought!
INachi graphic request thread-condensate_drain_line-jpg
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 7/29/15, 8:42 PM
Michael A. Clark, CMI's Avatar
Michael A. Clark, CMI Michael A. Clark, CMI is offline
The trap needs a clean-out. Those darn things get full of muck and clog, and it's impossible to get a coat hanger through it!
Michael A Clark, Certified Master Inspector®
Inspection Connection
St Albans, West Virginia
"Always tell the truth,
do what you say you will,
and do it Righter than Right...Always"
Facebook
Google Plus
www.charleston-home-inspector.com
www.icwvhomes.com
mclark@icwvhomes.com
Old 7/29/15, 9:47 PM
Jeffrey R. Jonas's Avatar
The one in Roy's graphic must be restricted... the water level is too low in the trap!
INachi graphic request thread-condensate_drain_line-1-jpg
Jeffrey R. Jonas
Owatonna, Minnesota
Old 7/30/15, 12:38 AM
Nick Gromicko, CMI's Avatar
Nick Gromicko, CMI Nick Gromicko, CMI is online now
CK is on vacation this week, but when he returns, he'll work on building them.
Old 7/30/15, 6:02 AM
Appreciate it!
Old 7/30/15, 9:11 AM
Some other ideas:
-Gas meter clearance graphic
-Don't vent bath fan to soffit graphic
-Venting bath fan out sidewall (best practice)graphic
Proper crawlspace vapor barrier graphic showing fastened to walls and seam tape
-Proper crawlspace/basement sill insulation (not fiberglass batts)
-Graphic showing why crawlspace/basement sill is a vulnerable area with air transfer
-No tees on horizontal plumbing drain lines graphic
Hundreds more to come
Old 7/30/15, 10:09 AM
- Proper flex ducting strapping graphic
- Proper flex ducting installation graphic
- Plumbing vent to small/frost closure graphic
- S-trap to P-trap conversion graphic
- Metal column attachments at beam and floor graphic
Old 7/30/15, 10:10 AM
CSST bonding graphic
Old 8/3/15, 6:44 AM
Meter base J-block for vinyl siding or any J-block graphic(s)
Steel post column top plate dishing graphic
Hose bib pitch graphic
Old 8/3/15, 7:38 AM
Footing drain tile graphic
Old 8/3/15, 11:00 AM
Chris Krowiak Chris Krowiak is offline
InterNACHI Staff
I'm on it!
Old 8/4/15, 7:47 AM
Rubber roof defects/conditions like ponding, ripples, wrinkles, and "alligatoring"
Window hermetic seal failure/causes graphic
Gas fireplace safety damper clamp graphic
Ceiling fan clearance-to-floor graphic
