Old 3/6/06, 10:33 AM
Hank Vanderbeek, MPA, CMI Hank Vanderbeek, MPA, CMI is offline
Certified Master Inspector
Default Isomere insulation and roof ventilation
The roof is metal and the bldr put in isomere insulation against the substrate but did not ventilate - no ridge, soffit or gable vents. Said not needed bec of the "effect" of new type of insulation. Anyone have any experience with this type of insulation and ventilation?
Old 3/6/06, 11:26 AM
Randy A. Glenn Randy A. Glenn is offline
Default Re: Isomere insulation and roof ventilation
Was that sprayed directly to the bottom of the metal panels ? Or to the bottom of the plywood decking ?
Old 3/6/06, 4:14 PM
Harvey Gordon, MRSA651's Avatar
Harvey Gordon, MRSA651 Harvey Gordon, MRSA651 is offline
My understanding is it's the only approved way to "not vent" an attic.
Harvey Gordon
- President -
FloridaNACHI
(The OFFICIAL Florida State Chapter of NACHI)
SEFloridaNACHI
(Serving NACHI Members in Martin, Palm Beach, Broward, Miami-Dade, and Monroe Counties)
______________
Questions or Comments about FloridaNACHI or if you would like to start a LOCAL Florida Chapter may be sent directly to me at hgordon@fl.nachi.org
______________
Old 3/6/06, 8:10 PM
Jeff Merritt Jeff Merritt is online now
I have started reading up on this, Most of the roofing company's are not to happy with it, I don't know about the steel roof system. this is going to get intresting.
Old 3/10/06, 2:36 PM
I can't image an unvented attic, reagardless of the type of insulation, especially new brands.
Would love to know what u have found in your reaseach.
Tags
insulation, isomere, roof, type, ventilation
Question about exposed styrofoam insulation. mlong Exterior Inspections 11 10/30/16 10:50 PM
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
Vaulted Ceiling Insulation rcooke Canadian Home Inspectors 4 1/22/07 12:24 PM
