Hello, I am in the process of shopping for a moister meter and am so overwelmed by the amount available out there. what do you recommend as i dont want to spend alot of money and also is a electronic hydrometer also recomended.
I find that clients get intemenated by these measures and thus add more delays in the process of transactions how much is too much info.
Thanks
Tony
If you use the “Search” function on this message board you will find this topic has been discussed hundred of times through the years.
If your not familiar with the Search function its at the top right of the Message Board, simply type in Moisture Meters and you can read until your hearts content.
Search Forums
Show Threads Show Posts
Advanced Search http://nachi.cachefly.net/forum/images/2006/buttons/reply.gif
Thanks dale
