General Inspection Discussion This is a place for general discussion about the home inspection industry. Try to keep the posts topical, but they need not be as specific as the other areas of this board. |
Thread Tools |
Please provide your best narrative here for this Defect Winning Photo for this past January.
As Described here; https://www.nachi.org/forum/f11/new-n...e-award-80157/ The winner at the end of the year win the same prize and maybe more. What do you have to loose to participate? Nothing. ![]() January Troy N. Pappas The lint can still get out if the flap can't open...Right? ![]() CMI 2004-2017 Retired Awards Committee Member U.S. Member of the Year Winner 2009 45 Years Residential/Commercial Builder http://www.homeinspectorpro.com/ (Report Software) Submit your AWARDS NOMINATIONS here The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
jritter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lint: Can you see me now?
Let try again Rodent preventer for dryer vent improperly installed Last edited by jritter; 3/24/13 at 7:19 PM.. |
Cute thats a great start.
Lets see some more Thanks... Roy Roy Cooke Roycooke@sympatico.ca Here are a couple of strings of mine https://www.nachi.org/forum/f48/roy-cooke-amazing-118930/ https://www.nachi.org/forum/f48/thanks-roy-cooke-sr-59651/ https://www.nachi.org/forum/f13/rece...-cooke-106880/ ............ |
Chris, is that a Narrative you would use in your report to describe a defect?
Well the show is to come up with the best Narrative to describe the winning Defect winner for January.
There will be 12 paired winners at the end of the year that could win you $1000 or close to it. I am requesting Narratives that would be used in the report to describe this defect. The best one gets to qualify for the yearly Poll. ![]() CMI 2004-2017 Retired Awards Committee Member U.S. Member of the Year Winner 2009 45 Years Residential/Commercial Builder http://www.homeinspectorpro.com/ (Report Software) Submit your AWARDS NOMINATIONS here The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Rodent preventer for dryer vent improperly installed and unable to vent
Taken as an official Narrative John.
OK. Here's what I would write.
The dryer vent flap is improperly installed (upside down). The present condition can/will trap lint and create a potential fire hazard; Also will not allow the dryer to properly vent. This is a safety issue. Corrective repairs by a qualified person are recommended. |
Thanks real nice.
Now others. ![]() CMI 2004-2017 Retired Awards Committee Member U.S. Member of the Year Winner 2009 45 Years Residential/Commercial Builder http://www.homeinspectorpro.com/ (Report Software) Submit your AWARDS NOMINATIONS here The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
The dryer vent damper was improperly installed. This can cause venting problems and create unsafe conditions. I recommend having the dryer vent damper properly installed.
Juan Jimenez
A House on a Rock Home Inspections LLC God. Family. Home. 804-269-4321 Richmond Home Inspector Richmond Chimney Sweep Richmond Radon Testing |
· Safety Issue, Repair: We found the dryer vent exterior wall damper damaged. It should be replaced to prevent outside air, insects, rodents and birds from entering the duct. Make certain the duct is metal and at least 10 cm (4 in) in diameter and as short and straight as possible. Seal all leaks. Screened type wall damper needs to be cleaned regularly as lint accumulation will restrict air flow resulting in possible fire.
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Marcel you guys install screens on them in Canada?
Juan Jimenez
I don't but some do because of...
Dryer vent installed improperly. Current configuration is amateur/incorrect installation. In this configuration (flap unable to open) it creates a potential fire hazard, and at least prevents clothes dryer from properly, efficiently drying clothing. Recommendation: Install dryer vent to manufacturers specifications, so as to have the flap/louvers properly allow air to discharge, and still close when not in use.
![]() Mike Auger, CMI RI Reg. # 32856 RI Radon Lic. # RMC-142 RMB-096 (401) 578-4878 A U.S.A.F. Veteran Owned Company
If I see a screen on a dryer vent, I report it as a safety concern.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Searching for picture | Marc D. Shunk | Inspecting HVAC Systems | 2 | 12/1/08 7:42 AM |
Infrared Sample reports | dvalley | Thermal Imaging, Infrared Cameras & Energy Audits | 26 | 1/1/08 9:40 PM |
