Old 5/15/18, 8:03 AM
Charles H. Hodges's Avatar
Charles H. Hodges Charles H. Hodges is offline
Certified Master Inspector ®
Default Thermal Imager
I am building a new inspection bag and with it will be buying a new IR camera. Ive have done well with the Flir C2 but think I may want to upgrade. What are some suggestions?
Looking at Fluke too and their VT04 model or TiS10 (or S20) anybody have any comments on these or any other? The flir equivalent?
TIA
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/15/18, 8:06 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Default Re: Thermal Imager
Flir E4 or E8.... I have the E8 .
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 5/15/18, 8:12 AM
Jeffrey R. Jonas's Avatar
Vto4 is NOT a Thermal Camera! It is a Visual Thermometer!
I thought you said upgrade? All you are doing is moving to the next level of CHEAP!
If you're going to upgrade, UPGRADE!
Q: Did you answer all the questions in the "Question of the week" yet???
Questions of the Week 05/13/2018
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/15/18, 4:16 PM
and that is why I posted the question. I would have made a mistake. I've been fine with the bottom of the barrel C2, its at least alerted me as to what to look at closer with more sensitive equipment or the naked eye.
Since it sounds like you have experience, what would you recommend?
No I have not looked into any Q and A
Did I just post a thread that was just recently posted?
Old 5/15/18, 4:21 PM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
I use this one
Fluke Ti 32 Industrial Thermal Imager – Fluke UK
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 5/15/18, 4:28 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
TIA
What are you going to use the new purchase for will help you decide.
There are many choices for many different uses.
HTH
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
~retired~
The above post represents my personal opinion.
Old 5/15/18, 7:05 PM
I think it was member Bill Warner that authored a great article that would help you. I'll see if I can find it, and if I can, I'll post it here for you.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/15/18, 7:08 PM
Here you go. Hopefully this helps... C2 Comparison and review.... Dave Andersen, This is for you!
Jeffrey R. Jonas
Owatonna, Minnesota
Old 5/15/18, 8:49 PM
Awesome Jeffery! Thanks
Old 5/15/18, 8:56 PM
HTH
Larry, this is just for general home inspections. To locate potentials in what to look closer into.
Of course in FL, moisture is front and center and while I'll never rely on any TIC to do the job for me, I've been using a cheap C2 as a beacon on what to break out the more sensitive equipment out for. I also use it for electric, HVAC, heat loss, insulation.
Old 5/15/18, 9:52 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is offline
After looking around a lot and getting some very good advice from Charely Bottger, I was lucky enough to snag a barely used Flir E8 for $2100. Normally they retail for $3000.
The sub-$1000 options are tempting, but I could see that if I tried to use them in a professional setting would they would fall short in a number of ways. The consensus of opinion among practicing pro's reinforces that notion.
You could get a Flir E6 for about $2000 new, retail, but the resolution is not that great. Charley told me that it I would risk not capturing moisture signatures at that resolution.
From what I could see, the Flir E8 looked like the least expensive entry-level device that I wouldn't outgrow within the first year or so of ownership, but that's just my untested opinion.
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 5/15/18, 11:40 PM
Dan Bowers, CMI, ACI's Avatar
Dan Bowers, CMI, ACI Dan Bowers, CMI, ACI is offline
Have 2 Flir E8's and a Fluke Ti32
Getting ready to sell one of the E8's.
Let an inspector go and have no use for 3 IR's
Dan Bowers, CMI
Licensed Contractor / Builder
Certified IAQ2 Mold Inspector
Licensed HVAC Service Technician
EDI Certified Stucco / EIFS Inspector
iNACHI – US Member of the Year 2010
ITC / FLIR - Level I Infrared Thermographer
FHA - 203k Inspector / Compliance Inspector
ICC Code Inspector (Plmbg, Elec, Mech, Bldg)
Old 5/16/18, 12:20 PM
sent you a PM - let me know if your interested in selling one of them and when.
Thanks!
Old 5/16/18, 11:25 PM
Got no PM ............ try email
theholmescompany@hotmail.com
Dan Bowers, CMI
Old 6/2/18, 10:58 PM
Brett Lee Brett Lee is offline
Flir E6 is a good option with a lot more resolution
