Using Survey / Inspection camera
I have been using a head mounted survey camera to complete inspections. I use it mostly to make sure I do not overlook any items during a job. I would like to know if anyone has used clips in digital form for clients?
John, I don’t use one but would like to know what camera you use as I have thought about trying one in certain applications.
I use the adrenaline systems Survey Camera. You can check it out here:
http://adrenalinecamera.com/product_info.php?products_id=345
http://www.adrenalinecamera.com/images/adrenalinecamera/800118a.jpg
I have never used one, but how much recording time does it give you?
From post #3 link:
System Specifications
http://www.adrenalinesystems.com/images/adrenalinecamera/&adrenaline_checkmark.gif
****Record to SD card up to 8GB **(up to 8 hours of video / audio)
****Universal Mounting - One size fits all **
****Super Easy operation! **Completely fool-proof menu operation. This means immediate utility on the field without costly delays.
****Lightweight **Minimize fatigue during extended use.
**Runs on standard AA batteries. uses standard batteries to avoid directly re-charging which means in quick and easy filed power swap.
**USB connectivity . Unit can be connected directly to your computer for system functions.
is there a belt buckle version? :slight_smile:
No…but that sounds like a good joke…But I sometimes take it off to reach into tight areas to take a look later what is there!
