Old 10/19/15, 10:51 PM
David Asselin's Avatar
David Asselin David Asselin is offline
Send a message via Skype™ to dasselin
Default Water heater help
Hi, I'm new and need some help. Is this gas water heater direct vented and how about the efficiency?
Water heater help-img_0399-jpgWater heater help-img_0402-jpg
It's a 2013 Bradford White. I've done research but not sure. Please help if you can.
Thanks,
David
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/20/15, 12:29 AM
Russel Ray's Avatar
Default Re: Water heater help
Attachment 106167Attachment 106168
Thanks,
David
One can get the efficiency from the data plate. It's the part that says REC 33.9 gph. That means the recovery rate is 33.9 gallons per hour, not bad for a 40-gallon water heater.
You didn't give us a very good picture of the top but it looks like it's a standard gas water heater which is not direct vented.
House Key News
Getting your past Clients to work as hard for you as you worked for them.
Sign up at http://www.housekeynews.com
Old 10/20/15, 1:02 AM
Jeremy P. Hutchings, IOS.2284-RES's Avatar
Jeremy P. Hutchings, IOS.2284-RES Jeremy P. Hutchings, IOS.2284-RES is offline
That does not look like a direct vent water heater. The water heater in the picture appears to have a draft hood installed on top.
Old 10/20/15, 1:28 AM
Thank you guys, I really appreciate it. So it's mid to high efficiency, conventional heater type, natural draft?
Old 10/20/15, 9:02 AM
Erik Schmidt Erik Schmidt is offline
Rec is how quickly the water heater can heat water. Your pictured water heater efficiency is not great, it takes 25,445 BTU to heat 33.9 gallons 90 degrees (F), so efficiency is about 64%. Power vented water heaters are about 80% efficient. If the vent is plastic it means that most of the heat has been extracted from the exhaust, so more heat energy has been used for heating the water.
The heater in the pic is a conventional draft with a pilot light. A pilot light on a storage water heater is not an energy waste, it helps keep the water in the tank warm.
The best way to save energy usage for heating water is to use fewer gallons of hot water and lower temperatures
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 10/20/15, 9:17 AM
Russel Ray's Avatar
My tenants are pretty happy with their tankless water heaters. They don't waste cold water waiting for hot water to arrive so both their gas and water bills are lower.
House Key News
Old 10/20/15, 6:17 PM
Dominic DAgostino, CMI HI3957 Dominic DAgostino, CMI HI3957 is offline
On Demand and Point of Use are different concepts.
I've seen plenty of tankless units installed too far from a fixture such that it takes an eternity for the heated water to arrive; no different than a traditional storage tank. The method of heating the water doesn't change the delay due to distance or pipe routing/installation.
Dom.
_______________
Dominic D'Agostino
Home Pride Inspection Services, Inc.
Longwood, FL 32750
407-260-1533
