Old 11/27/13, 10:07 PM
Joseph A. Shively, III Joseph A. Shively, III is offline
Default Well water testing.
I am looking for information on well water testing. I have received a lot of requests lately from people with well water systems.
Joe Shively
Shasta Properties LLC
www.shastapropertiesllc.com
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/28/13, 12:00 AM
James I. McKinley James I. McKinley is offline
I just got setup with ETR labs for water testing They have a free test promotion in the InterNACHI newsletter. I did the test sent it in and within 48 hours had results via email. Then decided to setup with them and they were very helpful. They also will answer clients questions directly so you don't have to... Get the promotional test kit and see for yourself.
James McKinley
Professional Property Inspections
www.proinspectsocal.com
Old 11/28/13, 7:43 AM
Scott Frakes, CMI Scott Frakes, CMI is offline
Default Re: Well water testing.
There are do it yourself kits at the big box stores but I recommend using an EPA certified lab.
Your county health department lab will most likely have these kits for less than $50.00.
No matter who you use, they will require that your sample is back in their hands within 24 hours to start the bacteria culture test. This makes it near impossible to do a Saturday morning inspection.
Look around your area as there might be a privately owned lab that will work with you.
Good luck,
Scott
Old 11/28/13, 9:43 AM
Andrew A. Griffin, CMI's Avatar
Andrew A. Griffin, CMI Andrew A. Griffin, CMI is offline
Have any of you used these to get a baseline on quality? If this comes back with a high value then you get a lab analysis. Only because some of the lab tests are a few hundred dollars, before the inspectors markup.
https://www.waterfilters.net/mobile/...-Test-Kit.html
Andy Griffin
Griffin Inspection Services LLC
agriffin@griffinspection.com
412-407-2501
www.griffinspection.com
www.pittsburgh-home-inspections.com
Pittsburgh home inspections
Old 11/28/13, 11:52 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
For e-coli and colorform your county health dept will have what you need at a very low cost.
As for other testing which is usually nitrate,nitrite and lead just find a local lab and they will supply you with all the containers at around $50 per test.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 11/29/13, 4:13 AM
Dixita Bhati Dixita Bhati is offline
Please Note: Dixita Bhati is a non-member guest and is in no way affiliated with InterNACHI or its members.
What kind of contaminants do you want to test for?
Old 11/29/13, 9:13 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
It can vary. Why do you ask?
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
~retired~
The above post represents my personal opinion.
Old 12/2/13, 12:38 PM
Bob Clark, CMI's Avatar
Bob Clark, CMI Bob Clark, CMI is offline
I use a local lab.
Board Certified Master Inspector in NH
Footprintinspection.com
Google Plus
Facebook
Concord New Hampshire
Old 12/2/13, 1:32 PM
Chris Jacobi, HI01200061's Avatar
Chris Jacobi, HI01200061 Chris Jacobi, HI01200061 is offline
Send a message via Yahoo to cjacobi
Joe,
There are a number of tests that can be performed, but some states require the test be done by a certified lab.
The less expensive tests are lead, nitrite, nitrate, and bacteria. Testing for pesticides by a certified labs can cost $1,000 or more.
Chris Jacobi, CPI
Home Inspections - Termite Inspections - Radon Testing - Drinking Water Quality Testing - Thermography
www.GreatHomeInspector.net
Chris@GreatHomeInspector.net
Facebook
Serving Indiana from Indianapolis to Greenwood, to Franklin to Columbus to Seymour.
Old 12/29/13, 6:01 PM
Jay Wynn Jay Wynn is offline
Find a lab and build a good relationship with them
Old 12/31/13, 9:20 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
I used to travel the US and Canada teaching for NACHI, and one of my most popular courses was one called Certified Well Sampler. It want through everything, from well construction, natural and man-made contaminants, health effects, EPA guidelines, sample protocols, QA, chain of custody, and selecting a lab.
It is still available on disk.
Joseph Farsetta, CMI
Co-Founder, International Association of Certified Home Inspectors
Driven by Principles, Separated by Character
I Pledge... HONESTY. INTEGRITY. CONFIDENTIALITY.
www.trustyourinspector.org
The opinions and statements expressed herein are mine and mine alone. They should not be construed as legal advice, marketing advice, or specific to any area of expertise. Readers should weigh all factors equally and understand the verbiage and the context in which it was presented.
Old 1/5/14, 11:16 PM
Joe where can I find the Certified Well Sampler class?
Joe Shively
Validity of Certified Mould Inspectors - Snake Oil Salesmen?? mwilson1 Ancillary Inspection Services 308 6/3/13 4:36 PM
Water Testing in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services 0 1/9/09 3:17 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
