Old 6/29/18, 9:04 PM
Patrick Murphy Patrick Murphy is offline
Default Weird framing for a Truss system, thoughts?
I attached the photos of the truss system I inspected this morning. No ridge board? The Trusses are also 24 inches on center for the most part. There is an area where they are less than 16 inches on center.
Not sure what to recommend here. Anyone have any recommendations?
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/29/18, 9:15 PM
Default Re: Weird framing for a Truss system, thoughts?
Built in 88.
Old 6/29/18, 9:32 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
What makes you think it is a
Weird framing for a Truss system,...?
I don't believe I have ever seen a truss system with a ridge board and 24" on center is normal...16" o.c. is stronger, no?
The center struts do look a little out of alignment, though, and I can't tell if there is any diagonal bracing needed from the pictures.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 6/29/18, 9:36 PM
Were the center struts loose anywhere, especially on the bottom?
~retired~
Old 6/29/18, 9:37 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
24" OC is fine, as with anything less. Typically truss members over 5' have some type of bracing, stiff/strong back and/or horizontal bracing across the trusses is common practice. Blueprints should be reviewed to make a definitive recommendation.
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 6/29/18, 9:43 PM
That's coming back to me now, Dave...10' max spacing on lateral bracing (or, less distance on long spans for temporary),and as prints show for permanent.
https://prairietruss.com/wp-content/...cing-Guide.pdf
~retired~
Old 6/29/18, 10:42 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
What you have is a typical truss system. No visible issues. Trusses do Not have a ridge board. 24 inch on center is common.
You should consider brushing up on the Basic fundamentals of residential construction.
Old 6/29/18, 10:48 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Truss systems don't have ridge boards, and they are 99% of the time 24" OC. Is this the new norm now? Are we not getting the proper training anymore?
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 6/29/18, 10:58 PM
It would help immensely.
It appears so...CMI, too?
~retired~
Old 6/30/18, 12:55 PM
I am thinking of concrete tile roof systems I see here almost daily to
lighter materials would have different requirements .
www.FHIAPS.COM
Dfetty@FHIAPS.COM
(239)339-7380
Old 6/30/18, 1:09 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Mr. Murphy, I am sorry but if you have been doing 20 years of Inspections and a CMI as you claim on your Website, and don't recognize a standard roof truss system, you are definitely doing the public an injustice and falsifying your credentials to make an unethical charge for your services.
I would highly recommend another line of work to fit your capabilities.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 6/30/18, 1:24 PM
First, I am not a CMI, nor have I ever said I am. I would recommend you read the entire page (instead of the header) before you assume, and go out of your way to insult them.
In this photo you can see a ridge beam.
Ridge board must not be the right terminology for this system. I know it's not required but the truss webbing is at an angle I have never seen before. Not to mention an improperly supported package unit on the roof. I was asking for thoughts not insults. Thanks for the advice...
Weird framing for a Truss system, thoughts?-p6290056-jpg
Old 6/30/18, 2:04 PM
That's not a ridge board. It's part of gable end bracing, and not adequate for high wind loading. There is plenty of information out there on truss systems to research.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 6/30/18, 3:30 PM
The center struts were twisted. And they look out of allignment to me. Ive seen 24 and 16 OC obviously. I just don't normally see both used in one house.
Old 6/30/18, 5:01 PM
Yes, we don't see much of that up here.
~retired~
