Old 1/13/13, 4:08 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default How many through bolts in 4X4 deck post?
Would anyone recommend additional post/beam support?
How many through bolts in 4X4 deck post?-p1010028-jpg   How many through bolts in 4X4 deck post?-p1010029-jpg   How many through bolts in 4X4 deck post?-p1010013-jpg
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/13/13, 4:11 PM
Juan C. Jimenez Juan C. Jimenez is offline
Default Re: How many through bolts in 4X4 deck post?
That would be an improper post to beam attachment in my report. The beam isn't bearing on anything
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Old 1/13/13, 4:23 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Very improper.
This picture is an improper way.
How many through bolts in 4X4 deck post?-incorrect-girder-post-connection-jpg
Old 1/13/13, 4:31 PM
Dave Range, CMI's Avatar
Dave Range, CMI Dave Range, CMI is offline
Chris,
Are those bolts just holding the beam together?
From the pics it looks like the beam is sitting on top of the 4X4's and not bolted to the 4X4's.
Hearth and Homes Inspections
440-954-0465
www.homeinspectorofmentor.com
www.euclid-home-inspector.com
www.hearthandhomesinspections.com
www.lakecountyohiohomeinspectors.com
Control your own destiny, or someone else will.
Old 1/13/13, 4:34 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
That connection is prohibited in the 2009 IRC deck code. And the posts should be 6x6's.
Stephen Stanczyk
Pierce County -Thurston County - King County - Kitsap County
Old 1/13/13, 4:40 PM
Banned
Yes I agree! notched to hold the beam.
Old 1/13/13, 5:22 PM
Originally Posted by drange View Post
Chris,
Beams bolted to post.
Also to other comments I'm well aware of the notched 6x6 requirement, unfortunately that's not how this deck was built.
Old 1/13/13, 5:30 PM
So Chris, out of curiosity, what did you put in your report?
Stephen Stanczyk
Old 1/13/13, 5:31 PM
Chris Walsh, CMI's Avatar
Chris Walsh, CMI Chris Walsh, CMI is offline
Agreed, that beam to post connection is prohibited. Notching is allowed as Kevin Wood says, but notching is a pain. I prefer a Simpson "Strong Tie" Cap/Base (BCZ) to attach the post to the beam. Looks like the posts are buried in the ground. That's not allowed in my jurisdiction. The posts have to be on 9" piers, 4 ft deep, and 6" above grade.
Chris Walsh
Manitouwadge, Ontario.
Retired (from Home Inspections)
Old 1/13/13, 5:36 PM
Recommend to strengthen support at post/beam at All post, including center post. Where two beams intersecting above one (center) post you may want to install a cleat down the side of the post. To install a cleat you will lay a short section of 2x4 flat against one side (inside) of the 4x4 support post flush with the top of the post and even with the bottom of the beam. Use a series of lag bolts to secure the cleat down the side of the post. This technique is used to expand the contact bearing of beams at the top of the post. Make sure the cleat is long enough and has enough bolts to pick up its share of the load, 3 feet is usually long enough. Note: Modern recognized building standards require All support post to be at minimum a 6" x 6" notched post; with beam resting on post.
Old 1/13/13, 5:39 PM
Post are on concrete footing, attached with approved post base brackets.
Old 1/13/13, 5:41 PM
Thanks for the info. Looked like the posts were just set in the ground.
Chris Walsh
Old 1/13/13, 5:47 PM
I agree, surrounded by decorative rocks, post base was just a few inches under rocks. I moved some away and probed with screwdriver.
Old 1/13/13, 5:51 PM
Hold the cleat with Lag bolts? Lag bolts? Didn't you mean finish nails?
Stephen Stanczyk
Old 1/13/13, 5:53 PM
Banned
We have rule on the MB Chris provide a link!
http://www.strongtie.com/ftp/fliers/S-DECKCONTP12.pdf
deck post question rjude General Inspection Discussion 5 9/17/10 10:26 AM
Using the Prescriptive Residential Deck Construction Guide mcyr Exterior Inspections 0 7/21/09 8:10 PM
Deck Posts jchamp Exterior Inspections 41 10/30/07 9:06 PM
Where's NACHI on this Website? lcapaul General Inspection Discussion 77 7/31/07 5:00 PM
