**** Is there any way that this wood cabinet door in front of the service panel is code compliant?
I removed the dead front cover plate.
Thank You
Thank You
What is your concern Marty?
That the door is wood?
Or the accessibility?
Or?
Just if it is safe and legal to have a wood door covering the panel
I have seen many designs on the net for wood cabinet doors that cover panels for decoration
No problem if there was a proper dead front behind the wood door…
Thank You
Like Larry said … Very Common
Be thankful you could get the dead front off. Sometimes it is blocked when they frame it in. Then it’s a problem.
