Modern standards dictate that ALL garage outlets be GFCI. Does this mean every single one should have the their own “test” button, or that they just be ran in sequence? Looking for this and additional information on kitchen GFCIs as well. Thanks for your input crew!
No! exterior and garage Outlets can be hooked up to a GFCI breaker.
Not all need a reset.
Depending on the circuit from the garage and the exterior Outlets
Yeah! Right! That should help ! Not!
Can you put words along with it…? Huh?
I suspect NO!
Go back and re-read the question in the OP. Only this time, read it real slow.
You might want to check that Roy.
Thanks. Hahahaha
Just posted this new article, which gives a brief overview of current (PUN!^) requirements:
