This is a image of a private drilled well with a pressure tank and a water filter.
The well is inside a wooden shed approximately 10ft x 10ft x 10ft.
The well cap is almost flush with the floor level with very little visablity to underneath the floor. The pressure tank is insulated and set on concrete blocking, the water line that I can see appears to be dry with a manual shut of valve before the pressure tank and after. I would reccomend a water test preformed to assure quality drinking water.
I think you’re supposed to post this in the thread associated with the class you are taking. Following instructions is also very important.
