Old 9/11/18, 12:13 PM
Michael G. Canavan Michael G. Canavan is offline
Post Mobil home slabs
I received a call from someone looking to install a mobile home on an existing mobile home slab. The new home is smaller than the original by 2' in the narrow direction and 6' in the long direction. The new mobile home installer wants to charge $28,000 to remove and replace the slab. Is there any reason to do this? other than profit.
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/11/18, 12:18 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Mobil home slabs
Most likely to bring it up to current engineering specs.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 9/11/18, 12:33 PM
The previous mobile home was about 7-8 years old?
Old 9/11/18, 12:38 PM
Where are you located...Please complete your profile.
Each manufactured home has its own unique engineering specs.But most are comparable.
If it were me I'd get a few setup quotes.
#1st Pro Inspection
Old 9/11/18, 1:54 PM
this is in Vermont
Old 9/11/18, 4:37 PM
Frank Rotte Frank Rotte is offline
Community Guest
The perimeter bearing walls would not be on the bearing point of the foundation. Is one reason I can think of.
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Old 9/11/18, 6:12 PM
Yep ! Frank!
There are so many reasons why the setup contractor decided to start fresh.
For one example ..Let's say the old slab didn't have proper footing...
Now! That is just one... We were not there..Nope!
I can think of about 2-5 more reasons to re-do it.
But, All I can do is speculate ..Yep!
#1st Pro Inspection
