sdubois1
(Shawn DuBois, HI8688)
January 24, 2015, 11:39pm
I’m sure this has been asked but I could not find an answer. Inspected a high rise condo. There was not main shut off in the main box. There were about 25 breakers in the box. I could not find a main shut off any where in the unit. In this type of structure, where are the main shuts normally located. The Bldg was built in 1982.
thx
ccurrins
(Christopher Currins, CMI)
January 25, 2015, 12:08am
2
At a high rise condo the service disconnect (main) is typically located at the meter, either at exterior or at meter room.
lkage
(Larry Kage, CMI)
January 25, 2015, 12:26am
3
We have many side by side connected condos wired the same way, up in this area. Then, the remote distribution (sub) panel is in the condo.
jjonas
(Jeffrey Jonas)
January 25, 2015, 2:23am
4
sdubois1:
thx
This is typically where I find the disconnect located at…
sdubois1
January 25, 2015, 1:21pm
6
Thank you. Assuming the meter and shut offs are behind locked doors and if the owner does not have access, do you gain access and look at the meter/shut off as part of a standard condo inspection?
ldapkus
(Linas Dapkus, CMI)
January 25, 2015, 1:54pm
8
sdubois1:
thx
So how did you explain this in your inspection report?
kleonard
(Kevin Leonard, CPI/CMI)
January 25, 2015, 3:35pm
9
And is required to be wired as such.
kleonard
January 25, 2015, 3:36pm
10
dandersen:
OMG…
My reaction to many of the posts I’ve seen here lately.
