Question?
Hello Internachi members.
I have a question about dryer vents going through a wall and terminating in the utility room next door.
Is that legal?
I’ll try to upload the picture.
Orin
Well, I cannot upload a picture. But just imagine the dryer vent terminating in the next room.
No can do. The dryer vent must terminate at the Exterior of the building.
Yep!
Thank you Gentlemen, well I finally am able to upload it from my laptop.
Smartphone could not upload picture.
Here it is.
I was asked to inspect a brand new Head Start building and found this. I have not started my report yet because I wanted to do more research. I will continue to follow up on it, thank you.
where is the alleged dryer duct? i only see metallic pipe
this is commercial?
what is the fire resistance requirement for that room?
numerous unsealed penetrations & incomplete fire tape & bed
isn’t backflow protection required for the sprinkler pipe?
if fire sprinkler prolly wrong material?
there is prolly more that i’m missing…
also insulation appears incomplete
Both ANSI/ASHRAE/IES Standard
90.1-2010 (90.1-10) and the 2012
International Energy Conservation Code
(IECC) requires any piping associated
with a heating or cooling system
that carries fluids with an operating
temperature of 105 °F or more or 60 °F
or less to be insulated; 90.1-10 further
specifies that the piping associated with
constant temperature water storage
systems must also be insulated (see
“Code Citations” for additional detail).
That does not look like a dryer duct to me. It looks more like a combustion air duct.
A six inch duct would be to large for a dryer vent. Like Barry said, there are other issues I hope you caught in your picture.
