It’s very easy to save electricity costs for your home. The hardest part is retraining your thinking on how you use electricity in your home.
- You need to drop you thermostat when using your heat buy a few degrees at night and drop it as much as you want when no ones at home. I’ve read that 1 degree of temp drop could save you as much as 2% on your heating bill.
- Replace your light bulbs with LED bulbs. Yes LED bulbs cost much more that incandescent bulbs but they last much longer and use only a trickle of the power to light.
- Tank-less water heaters use less electricity because they don’t continually run to keep a water tank always hot. They heat water when hot water is demanded, or as a hot water valve is opened and they cut off as soon as the flow of hot water is stopped.
If your in interested in learning more ways to save on home electric use visit:
**10 Easy Ways to Save Money & Energy in Your Home
right here on INTERNACHI.
