Old 7/24/18, 11:12 AM
John VanVleet's Avatar
John VanVleet John VanVleet is offline
Default Smoke detectors
So the law in Florida state that you need a smoke detector in each bedroom and the hallway leading to the bedrooms Older home that have had very little upgrades done over time, and have 1 SD in the hallway from 25 years ago would you call it out as a safety issue and recommend they install new ones in the bedrooms and replace the old one in the hall? or since there is one in the hallway leave it alone???? A Realtor said to me that if it's called out to add them then the buyers may run. I don't understand why someone would run when it's a life safety issue and could save their life!! What are your thoughts on this?
John Van Vleet
Certified Master Inspector
Florida State License HI-11019
941-224-6603
www.onlychoicehomeinspections.com
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/24/18, 11:19 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Smoke detectors
I don't and never have cared what the realtor thinks.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 7/24/18, 12:52 PM
Joshua L. Frederick Joshua L. Frederick is online now
I hardly ever see a house that incorporates the proper placement or prescence of smoke detectors and or CO detectors. Would that stop me from buying a house or making a big deal about it? Lol, heck no. Do I note in report? Yes.
http://aspecresidential.com
Defiance home inspector
Northwest Ohio home inspector
Old 7/24/18, 2:12 PM
Roy D. Cooke, Sr's Avatar
Just think if you do not write it up and there is a fire tonight . You sure will be on the hook .
I do not listen to agents opinion .
Yes write it up as needs immediate replacement as they are obsolete and missing in many areas .
Old 7/24/18, 6:29 PM
David Wigger, CMI's Avatar
David Wigger, CMI David Wigger, CMI is online now
I write it up as required in SOP.
I also tell the client that many local fire departments will come to the home and install smoke detectors as required at little or no cost. (usually no cost) FYI, the FD in my area will only do this for an occupied home, not vacant ones.
Old 7/24/18, 6:35 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
Absolutely call it out. If that realtor never calls you again you have lost nothing. In Florida when new smoke, and/or combo alarms are replaced, they are required to be replaced with 10 year non-replaceable battery type alarms. Safety first!
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 7/24/18, 10:19 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
^^^^^^^^^^This^^^^^^^^^^
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
~retired~
The above post represents my personal opinion.
Old 7/27/18, 9:58 PM
Stephen H. Payson's Avatar
Stephen H. Payson Stephen H. Payson is online now
In NJ, each jurisdiction has it's own rules on placement and the seller is required to get the Fire Cert before closing anyway. I just note the presence or lack of.
Stephen H. Payson
Peak Inspection Services
Office: 908-750-6789
NJ Home Inspection License #24GI00125400
NJ Radon Mesurment Technician License #MET13261
InterNACHI# 13081415
www.peakinspectionservices.com
steve@peakinspectionservices.com
Residential Inspections | Commercial Inspections
Serving all of Northern New Jersey
Residential & Commercial Contractor For More Than 34 Years!
