Old 7/21/15, 4:26 PM
John Olson John Olson is offline
Default Sperry Stop Shock hgt 6120
Has anyone else had problems with this tester. I kept getting a bad ground signal checked with my sure test and everything was alright. Tried it in another newer house same thing. Thanks John
Old 7/21/15, 4:38 PM
Andrew A. Griffin, CMI's Avatar
Andrew A. Griffin, CMI Andrew A. Griffin, CMI is offline
Default Re: Sperry Stop Shock hgt 6120
John, I have the "commercial electric" version (looks identical to the stop shock (purchased from Home Depot)), and I recently have been getting bad grounds on every plug. I was using this as a backup/double check to my ideal circuit tester. I switched back to just a normal three light tester as my double checker.
Andy Griffin
Griffin Inspection Services LLC
agriffin@griffinspection.com
412-407-2501
www.griffinspection.com
www.pittsburgh-home-inspections.com
Pittsburgh home inspections
