Old 2/16/19, 1:44 PM
Charles Catania Charles Catania is offline
Student Inspector
Default Water Pressure
Current inspection I just completed the water pressure in the kitchen sink
Is a trickle. Even though other sinks and tubs have normal pressure.
The turn off valves under the kitchen sink are on and there is
No clog on the faucet spout.
I recommend having a plumber check it out but my curiosity
Begs to know why.
If anyone has an idea of why this is happening
Your input is appreciated.
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/16/19, 2:03 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Default Re: Water Pressure
That's an issue with flow, not pressure. There can be debris or obstruction in the piping. supplies, cartridges spout or aerator, especially if the water lines are galvanized. If the flow is uniformly low for both hot and cold, it's likely to be in the faucet.
I strongly urge you not to check the stop valves in the future.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 2/16/19, 2:43 PM
Kevin M. Leonard, CMI's Avatar
Kevin M. Leonard, CMI Kevin M. Leonard, CMI is online now
Ditto that, it could be any number of issues.
Although I can understand the need to ask "why" because of curiosity, I tell my clients I quit asking "why" a long time ago, document out what you see in your report and sleep good tonight knowing you did your job.
Kevin M. Leonard
The Ohio Home Inspections Company
Cincinnati Ohio
513-895-7700
Old 2/16/19, 3:33 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
The first time that they leak and you can not get them off and you''ll know why Chuck made the above suggestion.
The best to you, Charles.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 2/18/19, 8:36 AM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
I recently replaced my kitchen faucet because it was getting old and also flow was low. The shut-off valves wouldn't hold so I had to close the main. When I disconnected the piping at the valves, there was debris from the rubber of the valves obstructing the flow. So as mentioned above, debris obstructing the flow is a possibility but there are other possibilities.
On The Level Inspection
Gatineau, Québec
Tags
pressure, kitchen, sink, water, begs
