Old 4/6/08, 9:45 PM
Kenneth R. Malone Kenneth R. Malone is offline
Default Asphalt shingles over wood shingles
Is it ever OK to put asphalt shingles over the original wood shingles? I did an older home (80+) that had two layers of asphalt shingles over the original wood. It has spaced board sheathing. Even though the current layer of shingles are only about 5 years old I feel the client needs to know the additional cost of having all this removed the next time he needs a roof. Because he will also need to have new sheathing installed over the spaced boards.
Old 4/6/08, 10:25 PM
Bruce D. Pinel Bruce D. Pinel is offline
Default Re: Asphalt shingles over wood shingles
Certainteed requires beveled wood strips be applied to all existing wood shingle courses to obtain an even base. This is to ensure good anchorage for fasteners and also to prevent an uneven base from telegraphing through.
Old 4/6/08, 11:02 PM
Ralph Brady's Avatar
Ralph Brady Ralph Brady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I see that quite frequently here. I have never seen ashpalt shingles over a shake roof, but over wood shingles is common.
I do make a comment that removal of previous layers and installation of sheathing will likely be required when reroofing.
Old 4/7/08, 2:44 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Certified Master Inspector
Ralph's right. Real important is that depending on jurisdiction, they may not allow re-installation of wood shingles or shakes. Most roof covering materials require a solid roof deck. That may mean ripping off spaced sheathing (usually boards) and replacement with OSB or plywood. This is a considerable expense and your client needs to know about it.
Kenton Shepard, CMI Inspector/Instructor
Director of Green Building
Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Old 4/7/08, 3:31 AM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
Down here many insurers will not write a new policy and have revoked policies in effect once they become aware of the comp over wood.
Never heard of tearing skip/spaced sheathing off we just overlay with OSB around here.
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 4/7/08, 4:25 AM
Russel Ray's Avatar
While I have heared of it, doing so is rare here, too, with roofers preferring to just overlay with OSB.
House Key News
Getting your past Clients to work as hard for you as you worked for them.
Sign up at http://www.housekeynews.com
Old 4/7/08, 2:33 PM
John Evans John Evans is offline
I am surprised the roof can support the additional weight with two layers of asphalt/fiberglass shingles. Average 400-500 lbs. per 10 Sq. Ft. for each layer, in addition to flashing issues when a roof is layered.
Retired Maryland Home Inspector
Infraspection Certified Level 1 No. 7801
johnevans1725@gmail.com
Old 4/7/08, 6:35 PM
Keith Swift, PhD. Keith Swift, PhD. is offline
In Los Angeles, since 1989, it has not been permissible to install any type of roofing material (including one that is Class-A fire-rated) over a wood roof on spaced-sheathing. Spaced sheathing is more seismically vulnerable and also can allow a fire to draft more rapidly, and the fasteners of the latest roof will have a tendency to split the old and often dry wood shakes/shingles, which means that the roofing material will also be vulnerable to wind-damage.
Old 4/7/08, 8:00 PM
Rick Maday's Avatar
Rick Maday Rick Maday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like you have 3 layers of shingles.
It would not be ok for 3 layers of asphalt shingles.
What is the difference?
2 layers, max.
John hit it right on the head!
Old 4/9/08, 10:10 PM
Thanks for all the responses. I basically wrote what I saw. I did tell them that when it came time for a new roof there would be considerable expense in removal. And yes the spaced boards would stay and osb would be used on top. The roofing estimate with removal was $18,000.00. Thanks, Ken </IMG>
Can someone explain why wood in contact with concrete causes rot? gromicko Miscellaneous Discussion for Inspectors 46 1/17/11 12:15 AM
Preventing Moisture related Problems mcyr Ancillary Inspection Services 1 12/19/07 9:30 AM
concrete roof tile over asphalt shingles Scott Schultz Exterior Inspections 1 3/29/07 7:32 AM
Extractd from the archives, Thanks Paul for this list! jtedesco1 Electrical Inspections 4 1/2/07 8:51 PM
