Second one this week. I suppose it saves on flashing? What if anything would anyone say about it?
I say that it’s wrong and it will be prone to moisture intrusion
Agree
I say that it’s improperly installed and not allowing ledger board to be tightly installed against the structure and prone to premature failure
Great! Thanks all
Mine is like that and the basement window under the deck leaks when it rains.
Simple and easy solution. Make it free standing, this is best anyways as there is zero chance of damages to the home.
That’s not going to solve the moisture intrusion problem.
Figure 21 on Troys Pdf and then adding repairs to the house. No issue after it is done correctly.
Lol lost in the sauce again Kevin? That’s not going to stop the moisture intrusion problem.
Did you give a “test” (rock it a little while standing on it)? :mrgreen:
