http://https://dl.dropboxusercontent.com/u/44690499/20160804_123240.jpg
http://https://dl.dropboxusercontent.com/u/44690499/20160804_175928.jpg
Hi There
Im looking for some in put on this deck extension Im currently working on, on my house.
The contractor had to add a ledgerboard. He cut a round hole in it for access my HRV intake and we built the deck over it. It appears that flashing and caulking was done properly (cut into tyvek, put flashing under and taped, as well as a plastic drip board, and caulked) however a concern I had was enough clearance for air flow to continue to be pulled into the HRV intake which is now under the deck. There’s 2 feet under the new addition where the intake is. The deck will NOT be closed off, and there’s a 4 foot clearance under the original deck which is now connected and all opened for air flow under and air flow going through all sides except for the side attached to the house
Im hoping snow drifts wont blow 8 feet under, and that I will be able to keep it clear of snow and ice, maybe even more so now that the new deck extension is covering it, it might actually protect it. Just want to make sure thats enough clearance for proper air flow and that it was flashed correctly.
Also, would it make sense for me to switch my HRV lines so that one is an output rather than input? Can that be done?
Any input is greatly appreciated
