Do exterior stairs have to be attached to a ledger the same way as a deck?
And therefore these nails are not really enough?
Should I recommend to be attached with 1/2 lagscrews.
Thanks
Where I am a landing would be required for exterior stairs over 3 steps, so there is that.
Check with the local AHJ, probably the same for them.
How are they being secured to the house? I see no bolts.
Those clip are not enough for the stringer. It should have stringer brackets.
This: Decks.com. Stair Stringer Attachment
And/or this: LSC Adjustable Stringer Connector | Simpson Strong-Tie
…would be more appropriate.
Great links Larry.
Good point.
The door swings inward, does it still need the landing?
Thanks
Good point.
Thanks
Regardless it looks FUBAR.
I’d write it up as structurally deficient. Yep!
Thank you all!
The only exterior stairs that do not need a landing are a secondary entrance with three steps or less and door swings away from the steps. YMMV, you need to check.
The primary exterior entrance always need a porch or landing so the SWAT team has a place to stand before they blow the door down and rush in with their automatic weapons.
