Old 9/25/11, 9:51 PM
John Overholser's Avatar
John Overholser John Overholser is offline
Question Two Flues, One Fireplace?
Hello everyone, I just did an inspection on Saturday. The thing that struck me as odd was there was a single chimney that had two flues visible at the top, but there was only one fireplace in the house and everything was electric -- no gas. Was the second flue just a rough-in for a second fireplace? Or do both flues serve the one fireplace?
http://www.ttbservices.com
MD License# 31233
WV HI4572294-0717
Infrared Certified
Mold Certified
Water Certified
Lead Risk Assessor
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/25/11, 11:38 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default Re: Two Flues, One Fireplace?
Do you have a photo?
My guess it's there for a fuel appliance flue, even though it's electric now, it's there if/when needed.
Old 9/25/11, 11:45 PM
ldapkus1's Avatar
ldapkus1 ldapkus1 is offline
Please Note: ldapkus1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree. I have 2 fireplaces and 3 flues. 1 for each fireplace and 1 for gas appliances.
Old 9/26/11, 12:12 AM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is offline
Electric furnace?
Upgraded to electrical furnace. In the basement there might be signs of oil pipe lead in on the chimney side.
Look for 3 inch circle on the exterior wall. Fresher brighter concrete patch for the hole. Oil tank pipe. If you can get to the chimney crown the liners will tell you there use.
Fire place will be charcoal powdery. Oil furnace will be oily residue.
Robert Young's Montreal Home Inspection Services Inc
Call (514) 489-1887 or (514) 441-3732
From the foundation to the roof, the basement to the attic. A detailed home inspection services every time!
Our Motto: Putting information where you need it most, "In Your Hands."
https://montreal-home-inspection services.com
https://home-inspectionservices.com
Old 9/26/11, 6:12 AM
Thanks for the replies guys. There definitely wasn't any indication of a previous oil tank or system...although the basement was finished, so hard to tell. It currently has a heat pump which was upgraded in '06. The house is an '89. I think I agree that it's just there in case they ever need it. Just seems strange to do that in a neighborhood that doesn't have gas lines.
MD License# 31233
WV HI4572294-0717
Infrared Certified
Mold Certified
Water Certified
Lead Risk Assessor
Fireplace clean and scan dmacy Interior Inspections 4 11/21/10 9:16 PM
Hearth size??? jcampbell Inspecting HVAC Systems 32 6/1/08 2:56 PM
The Rumford Fireplace: Safety vs. Efficiency mbryan Interior Inspections 2 4/28/08 5:38 PM
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 9:16 PM
