Old 5/10/07, 3:14 PM
William M. Corbett's Avatar
William M. Corbett William M. Corbett is offline
Default Gutters and downspouts
Does anyone have a good rule of thumb for distance between downspouts?
I am at an inspection (new construction) with a roof pitch of 12/12 and there is a distance of about 100 feet between downspouts.
Bill Corbett C.M.I.
Magic City Inspections LLC
Magiccityinspections.com
Old 5/10/07, 4:09 PM
Bruce M. Graham's Avatar
Default Re: Gutters and downspouts
I think that they recommend a down spout every 30 ft.
Bungalows to Mansions
Professional Inspection Services, LLC
Bruce M. Graham III, CMI
Gainesville, FL 32608
352 871 8989
CERTIFIED MASTER INSPECTOR
Certified Level II Infrared Thermographer
NACHI05091592
ICC 5268478
www.BungalowstoMansions.com
Old 5/10/07, 4:24 PM
That's what I thought as well, but this is the third new construction house I've seen like this in a month.
Bill Corbett C.M.I.
Old 5/10/07, 4:50 PM
Erol Kartal Erol Kartal is offline
Please Note: ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I believe distance between downspouts may be subject to local ordinance, but don't quote me.
Old 5/10/07, 5:19 PM
Andrew J. Frost Andrew J. Frost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
depends on how much roof surface it's serving.
i think i read 1 rainleader per square of roofing
Old 5/10/07, 6:56 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
This might help.
http://www.copper.org/applications/a...uts/intro.html
Marcel
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 5/10/07, 7:21 PM
Carl A. Brown's Avatar
Registered InterNACHI Vendor
William,
Did they have kickout diverters?
aka stuccoboy
Old 5/10/07, 8:23 PM
No, no kickouts. I would also think the roof surface area would play a part in the amount of downspouts.
Bill Corbett C.M.I.
Old 5/11/07, 3:14 PM
Ed Fako's Avatar
Ed Fako Ed Fako is offline
Please Note: Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
The correct answer per SMACNA is typically 40 feet maximum distance. This is assuming a 2" x 3" downspout leader pipe. The rain tables in the SMACNA manual also would further weigh on the distance.
Ed
Old 5/11/07, 7:30 PM
Dwight C. Chew, PE Dwight C. Chew, PE is offline
A lot of new construction in my area has the upper roof downspouts spilling onto the lower roof and then into the lower gutters. Use some common sense when making this type of determination. There may be no definite rule to go by.
There's nothing more stupid than 1/2 of a roof over a 2 story, 3000 sf house that has to drain everything through 2 downspouts. Poor design, poor installation.
Old 5/11/07, 8:17 PM
Larry Kage, CMI Larry Kage, CMI is offline
On asphalt shingles especially, that practice will cause premature wear where the concentrated water load is on the lower roof.
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 5/18/07, 1:34 AM
Terry Neyedli's Avatar
Terry Neyedli Terry Neyedli is offline
Please Note: tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
In our neck of the woods I was taught to go by the rule of 20-25 feet for a 4" gutter and 30-35 feet for a 5" gutter system. Seems reasonable to me.
We are very close to as area of Vancouver Island known to have one of the highest rainfalls in North America, 27 feet per year (Kildonan, B.C.).
T.Neyedli
www.alphahomeinspections.ca
Old 5/18/07, 9:49 AM
Rick Maday Rick Maday is offline
Please Note: Rick Maday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is it "right" because everyone is doing it?
I believe a D/S for every 40 ft of gutter is recommended. It may be worth a call to the builder(s) and ask them why.
</IMG>
Old 5/18/07, 9:54 PM
Brian E. Kelly's Avatar
Interesting thread, below is my standard gutter comment.
There are no gutters on the residence, which is common in Arizona. If drainage is a problem you may wish to add gutters.
Old 5/18/07, 10:42 PM
Ed Fako's Avatar
Here is a link from pathnet regarding this topic.
CHAPTER 4 - Rain and Water Vapor
Ed
Downspouts emptying on lower roof. wdecker Exterior Inspections 23 5/23/14 4:48 PM
Are gutters always necessary? kshepard Exterior Inspections 19 6/11/13 11:06 AM
Drainage & Grading dmacy Structural Inspections 10 2/15/06 8:18 AM
