Old 6/29/14, 11:34 PM
Nick Gromicko, CMI's Avatar
Nick Gromicko, CMI Nick Gromicko, CMI is online now
Default New patent for deck baluster bracket.
https://www.nachi.org/documents2012/US20140082921A1.pdf
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/30/14, 6:39 AM
John Paul de Oliveira's Avatar
John Paul de Oliveira John Paul de Oliveira is offline
Default Re: New patent for deck baluster bracket.
It seems to have some advantages. One drawback can be designed out.
He got his 20 claims in
John Paul Lucas de Oliveira
Home Sight Inspection, LLC
AHIT / GB-2 #86934 / AB #44580
Albuquerque, Rio Rancho, Edgewood, Placitas, Los Lunas, East Mountain Areas
505-620-4439
http://homesightinspection.com
into alternative engines?
check out: http://lucasengines.com
Old 6/30/14, 9:13 AM
Paul Lesieur's Avatar
Paul Lesieur Paul Lesieur is online now
Not very attractive.
Old 6/30/14, 11:39 AM
Frank Rotte's Avatar
Frank Rotte Frank Rotte is online now
That's revolutionary?
Old 7/2/14, 7:57 PM
Vaughn P. Adams, P.E. Vaughn P. Adams, P.E. is offline
InterNACHI Vendor
Frank,
Most certainly...all available 2" X 2" steel brackets or screws rigidly affix the baluster to the lower deck rail. Wood baluster shrinkage and subsequent moisture expansion leads to structural failure and potential loss of life and limb resulting from falls from failed balusters.
The Slip Tie Connector at the lower rail allows for vertical movement while maintaining its structural integrity.
Old 7/2/14, 8:03 PM
InterNACHI Vendor
I would be interested in knowing more about your "one drawback can be designed out"
Could you elaborate?
Old 7/2/14, 8:04 PM
Sean Fogarty's Avatar
Originally Posted by vadams View Post
Frank,
Huh?? Structural Failure of what? I have looked at hundreds if not well over 1000 decks at this point, and the only thing I find is broken or rotted ballusters. NO structural failure and no hazards to life or limb. Its not real difficult to replace an .86 cent balluster. If all that holds the railing on is ballusters, then it's wrong to begin with.
Personally, all that metal attached to the entire surround of the deck would probably be an eyesore IMO.
By the time the ballusters are becoming a hazard to life or limb, so is the rest of the deck.
Fogarty Inspection Services Group of Palm Bay FL
FL Licensed Home Inspector #8351
Infraspection Level 2 Thermographer #8788
FL Licensed Mold Assessor #MRSA2330
Certified Master Inspector
Home inspections, Commercial Inspections, Mold assessments, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
fogartyinspectionservices@gmail.com
www.homeinspectorpalmbay.com
Old 7/2/14, 8:31 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
I heard from a friend, whose daughter was on a second story apartment deck, and her toddler "staggered" over toward the edge railing to pick up a ball and stumbled/fell forward hitting his head directly on one baluster which gave way because it was rotten and split. The two, on either side of that one at 4" apart, held as his shoulders hit them. Otherwise, he would have gone down 8 to 10 feet to the ground whatever was below.
Apparently, it was old, cracked (where the air gun slammed 2 or 3 nails into it) and painted over with several coats.
Most every deck I see has some kind of potential hazardous safety issue.
Awards Committee Member
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
Larry Kage, CMI 2004-2017
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 7/2/14, 8:35 PM
I wonder how old the deck was??? Even with a metal clip at the base, the top still needs securing and still could crack. Clip or no clip, something 20 years old is goung to be pretty rough.
321-506-5125
Old 7/2/14, 8:58 PM
Juan C. Jimenez Juan C. Jimenez is offline
That is a bit excessive isn't it?
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Old 7/2/14, 9:46 PM
Larry writes:
That has been my experience as well.
Draft RESNET Standard now open for public comment John Snell Thermal Imaging, Infrared Cameras & Energy Audits 169 7/2/09 2:43 PM
Latent and Patent Defects gpallotta Canadian Home Inspectors 5 11/25/06 5:42 PM
