Old 8/11/17, 7:53 PM
Darryl Williams Darryl Williams is offline
Student Inspector
Cool This question does not have a correct answer - at least not for this test purpose
Taking the TX exterior FINAL test and came across this question:
Access openings must be a minimum of ___ inches high by ___ inches wide.
18, 22
16, 20
14, 16
15, 20
the answer should be 18,24
not any of the above fit that. Is there something I am missing?
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/11/17, 8:36 PM
Student Inspector
Default Re: This question does not have a correct answer - at least not for this test purpose
This was in the Structural Issues for Home Inspectors Course- EDU-000-9368-35
Old 8/11/17, 8:58 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
Certified Master Inspector ®
Access to what? Attics? Crawlspaces? Very vague!
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 8/12/17, 4:52 AM
Chuck Evans, TREC 7657's Avatar
Chuck Evans, TREC 7657 Chuck Evans, TREC 7657 is online now
Since it's an exterior class, I'll assume that the context is crawlspace access.
Since it doesn't specify whether the minimum is for access through a floor or through a perimeter wall, we'll go with the smaller requirement of the two (i.e., the perimeter wall), which is 16x24 inches. That is per the IRC.
If you are taking a TREC exam. the TREC SOP does not specify a minimum crawlspace size, but only states that you are not required to enter a crawlspace or any other opening less than 18x24, but it never states that that is a minimum measurement or that you need to report as deficient an opening that is less.
Does that clarify things for you, considering neither of those answers are available for selection under the exam question?
Chuck Evans (TREC #7657)
TheWoodlandsHomeInspection.com
Houston, TX
_______________________
Awards Committee Member
Old 8/12/17, 9:52 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
From the course...
This question does not have a correct answer - at least not for this test purpose-crawl-access-jpg
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 8/12/17, 9:54 AM
Joshua L. Frederick Joshua L. Frederick is online now
2 inches
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
