Old 12/17/18, 3:30 PM
John Holdway John Holdway is online now
InterNACHI Applicant
Default Step Cracks in wall Florida
Hi everyone, New to the site and also now training to be home inspector. I have a question about step cracks in stucco on a concrete block house in Florida. Are the step cracks a defect if the are very small. The reason I ask is because I sold a home a few years ago one inspector says there was structural damage because of them and one said that it was normal settling. I myself after taking the structural course would not comment either way but wanted to get experienced home inspectors opinions on the subject. House was approximately 13 years old, no other cracks on the interior or other signs of structure damage. Thank you in advance
John
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/17/18, 5:37 PM
David Wigger, #70000551's Avatar
David Wigger, #70000551 David Wigger, #70000551 is online now
Default Re: Step Cracks in wall Florida
I am not familiar with Florida conditions, but in Oklahoma the cracking you described sounds like minor settlement. It is hard to give a definitive answer without seeing it though.
Old 12/17/18, 5:50 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Hairline step cracking is typical of unreinforced block construction. Slight settling or even thermal expansion / contraction is the cause. All minor cracking should be sealed and monitored. Anything wider than 1/8", displaced, or asymmetrical should be deferred to a SE.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 12/21/18, 11:25 AM
Russell G. Cloyd's Avatar
Russell G. Cloyd Russell G. Cloyd is online now
Difficult to say without photos. All cracks are a sign of movement of some type.
Russell G. Cloyd
House 2 Home Inspections, LLC
859-739-7858
KY License #166164
Certified Radon Measurement Specialist
Certified IAC2 Mold Inspector
KY Fire Prevention Inspector
www.house2homeinspectionsllc.com
Old 1/4/19, 2:17 PM
Sorry meant to post the photo, here it is
Step Cracks in wall Florida-wall-crack-jpg
Old 1/4/19, 2:32 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
"Some cracking on the block wall was noted in a few areas around the perimeter of the dwelling. These generally appeared to follow the mortar joints between the courses of blocks (stair step pattern) and are a normal occurrence found in homes of this design. We did not notice any wall deflection or evidence of racking to door frames or window openings in these areas at the time of the inspection. We recommend these be sealed and monitored for further movement. "
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 1/5/19, 6:14 AM
William C. Chandler, CGC, CIEC William C. Chandler, CGC, CIEC is offline
step cracks are covered in most study books and the nachi exterior training
www.thebuildinginspector.net
William Chandler
Licensed Home Inspector #1025
Certified General Contractor #CGC060389
Licensed Mold Assessor, MRSA2209
HUD 203K Consultant #A0954
