Old 6/29/18, 7:05 AM
Paul M. DiVincentis Paul M. DiVincentis is offline
Default Stucco Siding Issue
Can anyone tell me what they think is causing this? It is on a home in San Jose. The temperature that day was about 75,clear and dry and this was the west side of the home. The darker areas were 5 degrees or so hotter and the moisture readings were lower on the darker areas. I first thought maybe the irrigation system caused this but I don't think this is the case. Thank you Stucco Siding Issue-100_1562-jpg
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/4/18, 4:20 PM
Aaron D. Miller's Avatar
Aaron D. Miller Aaron D. Miller is offline
Certified Master Inspector
Send a message via ICQ to amiller
Default Re: Stucco Siding Issue
Water Damaged Stucco – Types and Causes | Thom On Plaster
www.texasinspector.com
"What the plainspoken man lacks in subtlety he makes up in clarity."
Old 7/4/18, 5:51 PM
Gary D. Rowden Gary D. Rowden is offline
To me it looks like stucco repair (peeling/cracks) with a poor color match.
