Old 3/14/19, 6:07 PM
Larry King Larry King is offline
Default Vinyl Installation Window Question
Inspected home built in 2016 with vinyl widows installed and Fiber cement siding. Windows appear flush with siding on sides and bottom, but there is a gap at top.
Should this area be caulked? Does it appear to be installed correctly? If appropriate house wrap, tape and flashing are installed would this be a problem?
Is it the appropriate window to be installed with Fiber cement siding?
A lot of questions... but looking for answers/suggestions.
Thanks
Vinyl Installation Window Question-vinyl-window-jpg   Vinyl Installation Window Question-vinyl-window-2-jpg
Old 3/14/19, 6:41 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Default Re: Vinyl Installation Window Question
Why windows leak in new construction Houston homes
https://www.jameshardiepros.com/geta...hz10-us-en.pdf
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Tags
installed, siding, cement, fiber, vinyl
