Old 11/29/12, 11:27 PM
John Safstrom John Safstrom is offline
Default Weep hole location above windows
I normally see weep holes in the 1st row of brick veneer above windows. This house had them 5 rows up. This seems to defeat the purpose, but I haven't been able to find a reference to required weep locations.
Weep hole location above windows-p1080014-jpg
John Safstrom
TREC #10566
Systematic Home Inspections, PLLC
Allen,TX
www.systematichomeinspections.com
john@systematichomeinspections.com
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/30/12, 12:35 AM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is offline
Default Re: Weep hole location above windows
Sorry for the edit.
I may be getting ahead of myself. They may also be vent holes.
The window have lintels. All look good to me.
Metal expands contracts and is under load. In Montreal there is little masonry at the brick shelf. The shelf course is bitumen sheet with masonry pointed weather joint. The weather joint is filled with polyethylene caulk colored and 5/8' thick to look like the masonry bedding.
Masonry bedding alone on a metal/steel brick shelf like the one in your photos have a tendency to crack laterally and wonder vertically.
Robert Young's Montreal Home Inspection Services Inc
Call (514) 489-1887 or (514) 441-3732
From the foundation to the roof, the basement to the attic. A detailed home inspection services every time!
Our Motto: Putting information where you need it most, "In Your Hands."
https://montreal-home-inspection services.com
https://home-inspectionservices.com
Old 11/30/12, 8:50 AM
Barry Adair's Avatar
Location: this side of Texas dirt, another successful day
no adding, editing, deleting just a few facts
location of masonry veneer weep holes and flashing is specified by code and most masonry mfr
old concept/requirement, nothing new (see pdf)
R703.7.6 Weepholes. Weepholes shall be provided in the
outside wythe of masonry walls at a maximum spacing of
33 inches (838 mm) on center. Weepholes shall not be less
than 3/16 inch (4.8mm) in diameter. Weepholes shall be located immediately above the flashing.
R703.8 Flashing. Approved corrosion-resistive flashing shall
be provided in the exterior wall envelope in such a manner as
to prevent entry of water into the wall cavity or penetration of
water to the building structural framing components. The
flashing shall extend to the surface of the exterior wall finish
and shall be installed to prevent water from reentering the exterior wall envelope. Approved corrosion-resistant flashings
shall be installed at all of the following locations:
1. At top of all exterior window and door openings in such
a manner as to be leak proof, except that self-flashing
windows having a continuous lap of not less than11/8
inches (28 mm) over the sheathing material around the
perimeter of the opening, including corners, do not re-
quire additional flashing; jamb flashing may also be
omitted when specifically approved by the building official.
2. At the intersection of chimneys or other masonry
construction with frame or stucco walls,with projecting
lips on both sides under stucco copings.
3. Under and at the ends of masonry, wood or metal copings and sills.
4. Continuously above all projecting wood trim.
5. Where exterior porches, decks or stairs attach to a wall
or floor assembly of wood-frame construction.
6. At wall and roof intersections.
7. At built-in gutters.
File Type: pdf Flashing and Weep Holes Required 1994 SBC.pdf (194.1 KB, 1614 views)
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
National Association of Commercial Building Inspectors & Thermographers™ Member ID 12011-14TX
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 11/30/12, 9:46 AM
James T. McGrail, HI-3097's Avatar
James T. McGrail, HI-3097 James T. McGrail, HI-3097 is offline
Good to have you as a member, you always have good information, thanks for taking time to help others.
Old 11/30/12, 9:56 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Certified Master Inspector
Incorrectly placed weeps. They should be above the lintel and flashed. There is no visible flashing where they are now. Of course, now it can't be easily fixed. Just make them aware.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 11/30/12, 10:30 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with Joe! If there was a visible flashing then it would be OK. No flashing no go.
Old 11/30/12, 10:57 AM
No flashing was visible, and I showed the buyer while on site but I just wanted to make sure. Thanks for the info. House built in 1989, brick veneer.
John Safstrom
TREC #10566
Allen,TX
Old 11/30/12, 10:59 AM
PS. A lintel is not flashing. Without flashing, lintels will rust out.
Theodore Roosevelt
Ph: 704-351-1776
no it wouldn't be ok
the required weep holes and flashing above the window/shelf angle are not present as depicted in the op pic
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/30/12, 11:20 AM
Banned
I don't think you are understanding what I mean Barry. You still need weep holes at the lintel and it is better to have a flashing however you are allowed to have a weep holes anywhere you want as long as the flashing is below it. I did not say that it is correct because it clearly is not in this picture.
Not OK for having no weep holes above the lintel but Ok to have weeps at another location also.
Old 11/30/12, 2:16 PM
Sorry all. I thought I was on Bob posts.
Deepest apologies Mr. Adiar.
Not much sleep over the past 72 hours.
I do not call out the lack of flashing on window lintels on residential in my area.
Nor do I pay much attention to weep holes unless the building is built within the last 20 years.
Sorry.
I understand about rust staining and frost in my area.
I call out what I can see.
Not enough information in the photo. Sorry.
Old 11/30/12, 2:49 PM
Here are some examples.
I have no worries about a wood or metal framed buildings up to 4 units..
Attachment 60626
Attachment 60627
Attachment 60628
Attachment 60629
can you see flashing?
The flashing, when there is one at the lintel, can be and most likely is polyethylene 6 ml. that is cut before the iron and under the masonry.
Flashing and capillary breaks are applied on brick shelf's that tie into wall openings if the building is commercial or large residential.
I have never seen flashing on lintels on residential 1 and 2 unit building in my 35 years. I rarely see weep holes under windows or on the foundation shelf but will say that are gaining prominence seeing that homes are becoming more air tight.
Again it is dependent upon the engineered design of the wall.
NOTE The flashing is under the masonry. If it is poly plastic is cut at the metal edge and you will rarely see it. I have never seen metal and I am starting to see blue skin on metal shelf's on concrete stacked condo's and plastic (blue skin with weep holes on foundation. But again only small or large commercial..
Many years have passed me by and I have not heard of a home that had gypsum board and paint issues due to the lack of weep holes.
I am speaking locally only.
JMO
Old 2/3/15, 12:37 AM
Andrew Edery Andrew Edery is offline
Please Note: Andrew Edery is a non-member guest and is in no way affiliated with InterNACHI or its members.
that is odd
Andrew Edery
Genispec inspections
http://www.genispec.com
President Obama pours money into Energy Upgrades kwood Green Building Inspections 24 1/10/12 11:31 PM
Free floorplan drawing software bundle (Windows mobile, Tablet & Desktop)... Suresh Kumar General Inspection Discussion 12 7/8/09 12:20 PM
To weep or not to weep! rgant Exterior Inspections 14 2/15/07 1:40 PM
