Old 3/31/15, 2:16 PM
David Asselin's Avatar
David Asselin David Asselin is offline
Send a message via Skype™ to dasselin
Default Attic and Poly Question
Why isn't there a poly to act as a air/vapor barrier between living space and attic? I read that if there is too much venting in the attic, it can create a negative pressure drawing warm most air from the living space up in the attic. Also if there isn't enough insulation, warm moist air is again a problem going in the attic. Why not have a polyethylene on the ceiling after the drywall like on outside walls?
Thanks
David
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/31/15, 4:25 PM
Kenneth A. Ramm Kenneth A. Ramm is offline
Default Re: Attic and Poly Question
Thanks
David
It was not always this way, When was the home built?
Kenneth (Kenny) Ramm
608-438-3986
RammHomeInspections@gmail.com
Wisconsin License 2516-106
InterNACHI #12101905
Level II Infraspection Institute Certified Infrared Thermographer #10786
"If you want to live a happy life, tie it to a goal, not to people or objects." Albert Einstein
Old 3/31/15, 4:38 PM
Hi, it's a general question for new homes. Thanks.
Old 3/31/15, 7:26 PM
Dallas Nagy Dallas Nagy is offline
Default
It should be installed on warm side of insulation. Walls and ceilings in all of Canada. It goes on right before drywall goes up. Not all city's require a poly inspection for code compliance, but a quick look on the Burnaby website indicates they do have a poly stage inspection before drywall goes up. It has been a code requirement to have since late 80's I belive.
Old 3/31/15, 7:54 PM
On the ceiling? I know about outside walls but I never see it on the ceiling and was wondering why. Thx
Old 3/31/15, 7:58 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Money!
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 3/31/15, 8:06 PM
Here these are from another thread today.
http://www.airbarrier.org/resistive/...e_barriers.php
http://www.greenbuildingadvisor.com/...vapor-retarder
http://www.greenbuildingadvisor.com/...vapor-barriers
608-438-3986
Old 4/1/15, 8:30 AM
Erik Schmidt Erik Schmidt is offline
They must do things differently in BC
Alberta houses have poly on the ceilings under the attic.
Even my 1951 house has a sort of wax paper over the plaster ceiling.
Without looking it up, the code probably specifies vapor barrier, with a minimum number of perms.
There are other ways to accomplish that without using poly.
Talk to a home builder or code inspector in your area to get the real story, not likely that builders are not following code, given the problems that BC has been having with condos and such.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 4/1/15, 8:49 AM
Robin Wells Robin Wells is offline
Thanks
David
I would check building code.. but it sure is required in Ontario.. and I suspect in BC as well.
Robin Wells, CMI
Barrie, Ontario, Canada
Wells Home Inspection Services
Midland, Ontario, Canada
RAW Chimney Cleaning & WETT Inspections
Old 4/1/15, 8:49 AM
Do they insulate the ceilings.. if so should have vapour barrier.
Robin Wells, CMI
Old 4/1/15, 8:51 AM
Do they insulate the ceilings.. if so should have vapour barrier. No, seriously they are supposed to have it.
Attic and Poly Question-bc-vapour-barrier-jpg
Robin Wells, CMI
Old 4/1/15, 10:18 AM
Thanks,
David
Old 4/1/15, 10:23 AM
Default
I have insulated homes in 5 different provinces. It is always required in new homes and has for quite some time.
At what stage are you looking for it? Digging through blow in insulation during inspection?
If the installer put the poly on real tight and straight without wrinkles, and you are looking for it from the attic digging through blown in cellulose with a weak flashlight... yeah you might not see it readily.
