Old 8/21/18, 5:04 AM
Mark Giangarra Mark Giangarra is offline
Default Barometric damper on wood stove
Barometric damper on wood stove? Good or bad idea. Please ignore the bag over the end. Some kind of way to prevent cold area from getting in guess.
Barometric damper on wood stove-img_4466-jpg
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/21/18, 5:37 AM
Roy D. Cooke, Sr's Avatar
Default Re: barometric damper on wood furnace
What did google say ???.
Try it.
Barometric damper on wood stove? - Google Search
Please go top ...Control Panel and put in your info Thanks ... Roy
Old 9/17/18, 12:16 PM
Russell G. Cloyd's Avatar
Russell G. Cloyd Russell G. Cloyd is offline
Default Re: Barometric damper on wood stove
Can be beneficial (longer burn times, increased heat in the home) if installed properly. Consult the stove manufacturer's installation instructions for proper venting.
Russell G. Cloyd
House 2 Home Inspections, LLC
859-739-7858
Certified Home Inspector
KY License #166164
Certified Radon Measurement Specialist
Certified IAC2 Mold Inspector
KY Fire Prevention Inspector
www.house2homeinspectionsllc.com
