Old 5/25/18, 11:35 AM
Joshua LeBeau's Avatar
Joshua LeBeau Joshua LeBeau is offline
Default Blackened Insulation
Walk-In closet had a noticeable black stain on the ceiling away from attic opening. When I popped the attic access I found the insulation around the opening was blackened.
Does this look like mold or smoke damage?
Blackened Insulation-2018-4-24-53-jpg   Blackened Insulation-2018-4-24-47-jpg   Blackened Insulation-2018-4-24-49-jpg   Blackened Insulation-2018-4-24-51-jpg
Joshua & Michelle LeBeau
www.HomeInspectionsbyJML.com
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/25/18, 12:05 PM
Roy D. Cooke, Sr's Avatar
Default Re: Blackened Insulation
Poor gasket is allowing house air leak into the attic .
Stains are a combination of a smoker , cooking fumes and possible no stove ,bath room & dryer ,Vent to the outside .
Old 5/25/18, 12:08 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Yep!
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 5/25/18, 12:16 PM
Thanks Roy,
Attic access is on second floor.
The kitchen is on first floor and other side of house, 1st & 2nd floor bathrooms vent outside, same for dryer.
Maybe current owner is a closet smoker?
Old 5/25/18, 12:20 PM
Chuck Evans's Avatar
Originally Posted by jlebeau2 View Post
Thanks Roy,
It acts just like a return filter that never gets changed. Dust alone will do it.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 5/25/18, 12:54 PM
Thanks Chuck,
That seems about right.
Old 5/27/18, 7:25 PM
Russell G. Cloyd's Avatar
Russell G. Cloyd Russell G. Cloyd is offline
Perhaps it is a sign of a closet meth smoker.
Russell G. Cloyd
House 2 Home Inspections, LLC
859-739-7858
KY License #166164
Certified Radon Measurement Specialist
Certified IAC2 Mold Inspector
KY Fire Prevention Inspector
www.house2homeinspectionsllc.com
