Old 3/30/18, 10:39 AM
Paul E. Christenson, 5312219 Paul E. Christenson, 5312219 is offline
Default Crawlspace vapor retarder
Long over due first post…and currently studying the ‘Interior Rooms’ course. Is a layer of polyethylene sheeting (vapor retarder) a cause for not entering the crawlspace?
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/30/18, 10:42 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Crawlspace vapor retarder
Not at all.
Enter all safe, accessible crawls.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 3/30/18, 10:46 AM
So crawl lite and slowly and if you happen to rip the sheeting so be it?
Old 3/30/18, 10:53 AM
Yep! No big deal. That stuff is very heavy duty.
#1st Pro Inspection
Old 3/30/18, 9:33 PM
Thanks, Roy...and I suspect that it makes it a much cleaner and somewhat of a more agreeable endeavor.
