Garage Stairwell Fire Separation
I recently inspected a new home pending closing, with a walled but open stairwell at the rear of the garage leading to the common (non-separated) attic above the entire house. The gas fired split system heat pump is located in the attic. I advised my client that this stairwell would need a compliant doorset installed to preserve fire separation. The prospective owner discussed my report with the builder for rectification who advised her that the city inspector had issued a certificate of occupancy for the house therefore disregard my comments. The city uses 2003 versions of all codes. I don’t have access to my pictures at present otherwise I would post (will try later when back at the office) however, hopefully you will get the gist of my recommendation. In your opinion, would it be opportune to speak with the city inspector as I believe this totally contravenes fire separation requirements of the 2003 IRC:
https://www.nachi.org/forum/data:image/jpeg;base64,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
From IRC 2003
R309.2 Separation required. The garage shall be separated from the residence and its attic area by not less than 1/2 " gypsum board applied to the garage side.Garages beneath habitable rooms shall be separated from all habitable rooms above by not less than 5/8 " Type X gypsum board or equivalent.Where the separation is a floor to ceiling assembly , the structure supporting the separation shall also be protected by not less than 1/2" gypsum board or equivalent. (not Type X per se)
Comments appreciated.
Sounds like your assessment and recommendation is spot on. No need to speak to the AHJ. BTW, A home inspection is not a code inspection.
You should complete your profile so we know where you are located. It would also be a good idea to complete your signature area with company name and contact info. Helps with SEO.
As to your post: You make recommendations, and yours sounds fine, but it is the client who decides what to do about it, if anything.
Don’t surprised, as time goes on, that a vast majority of recommendations you make in your inspection reports are ignored by your clients.
The kicker happens when they have their lawyer send you a letter wanting you to pay for the repair or upgrade.
Gotta love this business!
Hope this helps
Cheers
I realize that we are not code inspectors but we also need to be aware of relevant codes to be able to provide sensible recommendations. I have been doing this for over 5 years now and nothing really surprises me regarding what the client decides to do, or otherwise, with recommendations!
https://www.nachi.org/forum/data:image/jpeg;base64,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
Tried to edit/insert image in original but it didn’t appear. Any clues as I tried to 1. copy and paste then 2. use the paperclip but it asked for a URL.
City inspectors pass all kinds of things that they shouldn’t. They have a lot of houses to inspect and little time to spend on each. They sometimes are not the most diligent. I never care about what the city passed.
Of course, if your client were to contact the city building department and point out your finding to them, they may well reconsider whether it should have been green tagged. Perhaps, if the client were to suggest that he might go back to the city for clarification, the builder may reconsider all on his own. I will provide my clients them all of the backup information (code references, installation standards, etc.) that they need to support my findings, but I do not attempt to negotiate for them.
Go to advanced edit view and click the attachment icon on the top row (mountain landscape icon with no paperclip)
Thanks Chuck, I didn’t realize the advanced option was where pictures were uploaded. I was trying to do this from the standard reply page, obviously with no luck.
At last, managed to post the picture of the open stairwell to the rear of the garage leading to a common attic above the entire house that I started this thread about. As far as I am aware, it is still in this condition after issue of the Certificate of Occupancy by the city.
