Old 6/13/06, 9:48 PM
Charles Buell's Avatar
Charles Buell Charles Buell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default height of windows above the floor
Does anyone know of a required minimum height for an opening window above the floor. For example lets say its a 32" wide double hung 60" tall and it is 24" off the floor. Wouldn't the window in the open position pose a fall hazard the same as a 24" railing around a deck?
Old 6/13/06, 10:00 PM
Gerry Beaumont's Avatar
Gerry Beaumont Gerry Beaumont is offline
Default Re: height of windows above the floor
Hi to all,
Charles the quick anwer is 18 inches, but her is the long answer
B] R308.4 Hazardous locations.
The following shall be considered specific hazardous locations for the purposes of glazing:
1. Glazing in swinging doors except jalousies.
2. Glazing in fixed and sliding panels of sliding door assemblies and panels in sliding and bifold closet door assemblies.
3. Glazing in storm doors.
4. Glazing in all unframed swinging doors.
5. Glazing in doors and enclosures for hot tubs, whirlpools, saunas, steam rooms, bathtubs and showers. Glazing in any part of a building wall enclosing these compartments where the bottom exposed edge of the glazing is less than 60 inches (1524 mm) measured vertically above any standing or walking surface.
6. Glazing, in an individual fixed or operable panel adjacent to a door where the nearest vertical edge is within a 24-inch (610 mm) arc of the door in a closed position and whose bottom edge is less than 60 inches (1524 mm) above the floor or walking surface.
7. Glazing in an individual fixed or operable panel, other than those locations described in Items 5 and 6 above, that meets all of the following conditions:
7.1. Exposed area of an individual pane greater than 9 square feet (0.836 m2).
7.2. Bottom edge less than 18 inches (457 mm) above the floor.
7.3. Top edge greater than 36 inches (914 mm) above the floor.
7.4. One or more walking surfaces within 36 inches (914 mm) horizontally of the glazing.
8. All glazing in railings regardless of an area or height above a walking surface. Included are structural baluster panels and nonstructural infill panels.
9. Glazing in walls and fences enclosing indoor and outdoor swimming pools, hot tubs and spas where the bottom edge of the glazing is less than 60 inches (1524 mm) above a walking surface and within 60 inches (1524 mm) horizontally of the water's edge. This shall apply to single glazing and all panes in multiple glazing.
10. Glazing adjacent to stairways, landings and ramps within 36 inches (914 mm) horizontally of a walking surface when the exposed surface of the glass is less than 60 inches (1524 mm) above the plane of the adjacent walking surface.
11. Glazing adjacent to stairways within 60 inches (1524 mm) horizontally of the bottom tread of a stairway in any direction when the exposed surface of the glass is less than 60 inches (1524 mm) above the nose of the tread.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/13/06, 10:04 PM
Dale Duffy's Avatar
R613.2Window sills.
In dwelling units, where the opening of
an operable window is located more than 72 inches (1829 mm)
above the finished grade or surface below, the lowest part of the
clear opening of the window shall be a minimum of 24 inches
(610 mm) above the finished floor of the room in which the
window is located. Glazing between the floor and 24 inches
(610 mm) shall be fixed or have openings through which a
4-inch-diameter (102 mm) sphere cannot pass.
Old 6/13/06, 10:07 PM
Thanks Jerry---I have all that I just think it is a little odd that a window without a barrier above 18" wouldn't be considered a hazard.
Old 6/14/06, 12:18 AM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Sometimes screens are considered a barrier.
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 6/14/06, 9:10 AM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Yes, for bugs.
Really, the ones labeled that I see state something like "CAUTION-This window screen will not protect against falling out. Children left unattended...blah, blah, blah.
Old 6/14/06, 10:31 AM
pdacey's Avatar
pdacey pdacey is offline
Please Note: pdacey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by dduffy
R613.2Window sills.
Which version of the IRC is this from? In 2003, R613.2 is performance.
Old 6/14/06, 10:34 AM
pdacey's Avatar
I run into this a lot here. Especially on new construction. San Antonio is on the 2003 IRC and there is nothing specific in it to prohibit this. I still call it out as a "potential" safety hazard for small children. I also tell the client that there is no "code" enforced here to make the builder change it.
Old 6/14/06, 12:18 PM
Dale Duffy's Avatar
2006
Old 6/14/06, 8:05 PM
Brian E. Kelly's Avatar
2006
Dale what jurisdiction has adopted the 2006 IRC?
"So, what are your thoughts on the Flir One??"
Old 6/14/06, 8:08 PM
Dale Duffy's Avatar
None in Arizona I know of. I don't have the UBC on a disk, the new one is coming out next year I think.
Old 6/14/06, 11:05 PM
Robert D. Armstrong Robert D. Armstrong is offline
2003 IRC R308.4 Hazardous Locations. pg48
Old 6/15/06, 2:48 AM
Will Handley's Avatar
Will Handley Will Handley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Dale,
Is the UBC still in publication? I thought that was the old ICBO publication which has since been merged into ICC - IRC Codes. I believe 1997 UBC was the last year. 2000 International Building Codes replaced same.
Old 6/22/06, 5:52 PM
Peter W. Bennett Peter W. Bennett is offline
Exclamation Re: height of windows above the floor
how low can you go?
height of windows above the floor-lowandlowerwindow-jpg
Where do I put the Aquarium? mcyr Structural Inspections 5 7/12/15 3:06 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Free Office Software Eqiv. For Download bmerrell Miscellaneous Discussion for Inspectors 4 12/31/06 12:47 PM
More water, different windows Brenda Exterior Inspections 12 9/22/06 3:55 AM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
