I am only making a guess…
Home was constructed with an Unfinished Basement Originally…
Later… Insulation was Improperly installed (vapor barrier down)
again
Later…
Basement area was Finished and the insulation was left intact…
Removal of the vapor barrier (paper) is recommended at a minimum to correct…
That is the normal progression of the same situation when discovered in this geographic area…
The tabs are not attached to the joists and the batts are loosely installed so the vapor retardant paper is pretty much useless. I don’t think moisture will accumulate on the paper since the temperature difference isn’t much between the 2 levels. I see it from time to time on new construction.
It probably happened like Joe H. described but I don’r see a problem because of what Linas posted. And Joe F. has a valid point about lack of harm so, David, I may comment but probably only verbally to the client. :mrgreen:
Dave mentioned that the basement is conditioned. For vapor retardant backed insulation, the tabs must be attached to the bottom of the joists to retard air/vapor movement. This installation will work as a noise barrier but vapors will migrate past the vapor barrier. It’s pretty simple. Some folks just don’t get it.
The basement is conditioned (with furnace in unfinshed area, has louvered doors, but the finished rooms are not being heated properly as you can see in the photo of the sealed registers. This would make unconditioned. (not sure the thoughts of sealing vents), most likely not enough heat/air going to 1st/2nd floors. (like Joe stated)
I see this insulation often but the vapor barrier often gets stained (moldy substance). I believe the best practice would be to use unfaced insulation between conditioned areas. (why I was posting)
Also this should go in HVAC but what are your thoughts on a make up air system for a high efficiency furnace that is bringing in outside air with the high efficiency venting?
