Interior Inspections Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, etc. |
Thread Tools |
I should have posted this into my previous post. This is a home built in 1930 and the paint in the walls are peeling and cracking. If you touch it it falls on the floor. I do not know of any paint today that does that. Particularly on the interior. Could this be lead based paint? I know it should be tested to know for sure, but is there a visual characteristic?
![]() Certified Inspectors of North Carolina LLC President/Member 910-578-4943 www.certinspectnc.com james@certinspectnc.com |
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Even the newest paint will do this if the surface is not properly prepared. Could be moisture or could be real old. With that amount, they will most likely meet the thresholds for lead based paint remediation by a trained and lead certified contractor.
![]() Stephen Stanczyk Washington State Licensed Home Inspector # 221 InterNACHI Lifetime Member RETIRED |
Paint on plaster often does this.
Consider it lead. Test. David A. Andersen & Associates Clarksville - Nashville Home Inspector Lic#40 (Retired) ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 HVAC Certification EPA Cert#2046620 ![]() |
Thread Tools | |
