Old 4/20/17, 12:55 PM
Al D. Bolt Al D. Bolt is offline
Default Photoelectric sensors
What would the reason be for mounting vehicle door opener photoelectric sensors near the ceiling?
Photoelectric sensors-dscn9315-jpg
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/20/17, 12:57 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
Default Re: Photoelectric sensors
Laziness.
On The Level Inspection
Gatineau, Québec
Old 4/20/17, 3:50 PM
Roy D. Cooke, Sr's Avatar
New home the builder uses it for storage and does not want door opening and closing all the time but they do not want the sensors to get lost very common in a new subdivision seen it often .
Old 4/20/17, 3:59 PM
That's odd. They're wired and working properly. No provisional wiring at the proper locations.
Old 4/20/17, 4:11 PM
Michael S. Gleeson, 16000070526 Michael S. Gleeson, 16000070526 is online now
I see it every now and then. It is just a way to bypass the sensors. I don't know why anyone wants to bypass the sensors but people do it.
Michael Gleeson, CPI
InFocus Inspection
NY License: 16000070526
716-548-0610
Serving Western NY including Erie, Niagara, Wyoming and Genesee Counties
http://www.infocusinspection.com
http://www.inspectwny.com
Old 4/20/17, 5:31 PM
Please reread post number three
Old 4/20/17, 6:13 PM
Dominic DAgostino, CMI HI3957 Dominic DAgostino, CMI HI3957 is offline
Doubtful.
The door opener will not function in the down direction without properly wired, aimed, and working photo electric sensors. They are mounted in inappropriate locations to bypass the safety protocol that prevents the door from closing with an obstructed or missing sensor, but this "method" still allows the door to close.
It's dangerous.
_______________
Dominic D'Agostino
Home Pride Inspection Services, Inc.
Longwood, FL 32750
407-260-1533
Old 4/20/17, 10:56 PM
Brian E. Kelly's Avatar
They are much easier to align like that
Old 4/20/17, 11:27 PM
Bob Elliott, 450.0002662's Avatar
Bob Elliott, 450.0002662 Bob Elliott, 450.0002662 is offline
They have eyes for each other .
Old 4/21/17, 6:44 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is offline
Another reason not right though but happens the sun was affecting the operation
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 4/21/17, 8:00 AM
I read it. I don't agree with it. I see it in old homes not new homes. People install openers and purposely bypass the sensors.
InFocus Inspection
716-548-0610
Old 4/21/17, 8:41 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Why?
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 4/21/17, 8:46 AM
Originally Posted by rlewis5 View Post
Why?
I wish I knew. I have seen it enough to know it is a thing but I have never asked a homeowner why.
I just googled "why do people bypass garage door sensors" and here is what came up:
"I always found myself ducking under the door as it was going down and also stepping over the beam. You know, hit the wall button, run out through the door and jump in the car... What I did was remount the two electric eye things up high out of the way about 1 inch apart."
InFocus Inspection
716-548-0610
Old 4/21/17, 8:58 AM
Why?
Ignorance.
Another answer to "why" is that they tried to get the new opener to work, found out it won't close, then realize they have to wire the sensors.
Easier to mount them 10 inches from the motor than to run the wires to the proper location.
_______________
Dominic D'Agostino
Longwood, FL 32750
407-260-1533
Old 4/21/17, 5:02 PM
Darren M. Kudlats, Mr Darren M. Kudlats, Mr is offline
Community Guest
As in they want to be Indiana Jones.
