Interior Inspections Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, etc. |
Thread Tools |
Using the following for reference: http://publicecodes.citation.com/ico..._15_sec003.htm
Range hoods shall discharge to the outdoors through a single-wall duct. The duct serving the hood shall have a smooth interior surface, shall be air tight, shall be equipped with a back-draft damper, and shall be independent of all other exhaust systems. Ducts serving range hoods shall not terminate in an attic or crawl space or areas inside the building. Exception: Where installed in accordance with the manufacturer’s installation instructions, and where mechanical or natural ventilation is otherwise provided, listed and labeled ductless range hoods shall not be required to discharge to the outdoors. Single-wall ducts serving range hoods shall be constructed of galvanized steel, stainless steel or copper. Where domestic kitchen cooking appliances are equipped with ducted range hoods or down-draft exhaust systems, the fans shall be sized in accordance with Section M1507.4. Exhaust hood systems capable of exhausting in excess of 400 cubic feet per minute (0.19 m3/s) shall be provided with makeup air at a rate approximately equal to the exhaust air rate. Such makeup air systems shall be equipped with a means of closure and shall be automatically controlled to start and operate simultaneously with the exhaust system. TABLE M1507.4 MINIMUM REQUIRED LOCAL EXHAUST RATES FOR ONE- AND TWO-FAMILY DWELLINGS AREA TO BE EXHAUSTED EXHAUST RATES Kitchens 100 cfm intermittent or 25 cfm continuous Bathrooms-Toilet Rooms Mechanical exhaust capacity of 50 cfm intermittent or 20 cfm continuous For SI: 1 cubic foot per minute = 0.0004719 m3/s. QUESTION: All that is REGARDLESS of the fuel-type of the range appliance - Correct? A gas range appliance should have an exhaust hood that discharges outside, just like an electrical range appliance should. Agree? BEN GROMICKO View Profile InterNACHI Chief Operating Officer InterNACHI Chief Academic Officer NACHI.TV Producer and Host |
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I recommend the installation of an exterior venting exhaust hood in all cases apart from any code.
Often my clients were unaware that the hood did not exhaust to the exterior of the building.
Note this code and commentary:
M1503.3 Kitchen exhaust rates. Where domestic kitchen cooking appliances are equipped with ducted range hoods or down-draft exhaust systems, the fans shall be sized in accordance with Section M1507.3. Commentary: This section does not require installation of a hood that exhausts to the outdoors for domestic kitchen cooking appliances. It only provides guidance for sizing the exhaust fans for hoods that do exhaust to the outdoors. Mechanical ventilation would be required only where natural ventilation is not provided (see Section R303). Other than the code I'm pasting below, I'm not aware of a code that requires a range hood of any type at all in a one or two family dwelling or townhome, although range manufacturer's recommend them (I think) and I definitely put it in my report if one is not present. If you do install a range hood, then the text you cited applies regardless of the fuel type. OVERHEAD EXHAUST HOODS M1505.1 General. Domestic open-top broiler units shall have a metal exhaust hood, having a minimum thickness of 0.0157-inch (0.3950 mm) (No. 28 gage) with 1/4 inch (6.4 mm) clearance between the hood and the underside of combustible material or cabinets.A clearance of at least 24 inches (610 mm) shall be maintained between the cooking surface and the combustible material or cabinet. The hood shall be at least as wide as the broiler unit, extend over the entire unit, discharge to the outdoors and be equipped with a backdraft damper or other means to control infiltration/exfiltration when not in operation. Broiler units incorporating an integral exhaust system, and listed and labeled for use without an exhaust hood, need not have an exhaust hood. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” T. Roosevelt Joe Funderburk, CBO, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC Angie's List Super Award Winner 2018, 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010. Ph: 704-351-1776 www.aohomeinspection.com ![]() |
Ben, I hope it's OK that I paste our emails here, to add further detail, since that's what originated this.
Any help from all will be appreciated. Mike, agreed. I have been recommending venting to the exterior on numerous new home warranty inspections with gas cooktops in the same developement, qouting from a InterNACHI course I took. The numerous clients are now asking for back up info/code for it. Original correspondence with Ben: Hey Ben, Here is a qoute from one of your Nachi courses (don't remember which one) that I have been qouting to clients that have gas cooktops but not vented to exterior. I call it out as a qoute from the InterNational Association of Certified Home inspectors: "Remember when evaluating homes with gas ranges or cook tops that gas code requires they be vented to the building exterior through a hard-ducted vent. Re circulating models do not satisfy the code requirement." I have numerous clients in a neighborhood that I noted this on their builders warranty inspection and are asking for backup to this opinion to get builder to correct this. Where you qouting this from IRC or what Gas code source. Where can I better review this at? Any info would be a big help. Even a code reference number. I enjoy all your courses and videos. Great job. Thanx, Joe Joe, Slam dunk. Here you go: IRC. Chapter 15. Exhaust Systems. Section M1503. Range Hoods. Hope that helps. Sincerely, BEN GROMICKO Hey Ben, thanx for the response. But that (IRC) doesn't really help back up the above qoute that I have been using with clients. The IRC 2006 M1503 section doesn't even differentiate from electric or gas range for venting and it has the exception of ductless vent a hoods 'shall not be required to discharge outdoors.' per manufacturers. So the IRC doesn't help with the statement I got from the InterNACHI course and have been qouting. - "Remember when evaluating homes with gas ranges or cook tops that gas code requires they be vented to the building exterior through a hard-ducted vent. Re circulating models do not satisfy the code requirement". So is there any back up to this statement that says gas code requires gas ranges be vented to outside? For instance the National Fuel Gas Code, International Gas Code, Fire Protection Agency, etc.? I thought I had seen something on it before but can't remember where. I have clients wanting more info on it. Thanx for any further help. Joe Joe, Understood. Let's ask here - and please join in - https://www.nachi.org/forum/f18/range...64/#post874927 Sincerely, BEN GROMICKO Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com ![]() |
I do not cite code.
I recommend installation of a exhaust hood to improve indoor air quality regardless of a gas or electric cook top. It really depends on how the owner cooks. It's up to them. Unless you are a code enforcement official you are biting more off than you can chew. You are paid to offer your opinion and recommendations.
It seems clear from the following:
SECTION M1503 RANGE HOODS M1503.1 General. Range hoods shall discharge to the outdoors through a single-wall duct. If an inspector sees a range hood (installed over a range appliance in the kitchen), then it must discharge outside. (Let's say... according to best practice techniques) Clear? No? BEN GROMICKO View Profile InterNACHI Chief Operating Officer InterNACHI Chief Academic Officer NACHI.TV Producer and Host |
![]() Quote:
Augh.
It seems clear from the following: SECTION M1503 RANGE HOODS M1503.1 General. Range hoods shall discharge to the outdoors through a single-wall duct. There is an exception to this rule. If an inspector sees a range hood (installed over a range appliance in the kitchen), then it must discharge outside. (Let's say... according to best practice techniques) Clear? No? BEN GROMICKO View Profile InterNACHI Chief Operating Officer InterNACHI Chief Academic Officer NACHI.TV Producer and Host |
Ben, the exception is very clear. If designed as such it is a listed vnent hood is DOES NOT REQUIRE exterior venting
![]() Why dance about this? I make my recommendation apart from what the code says.
![]() Quote:
There is no reason to call a re-circulating range hood a defect unless it's a broiler ('jenn-air' type range). I simply identify the the type of hood (re-circulating, or exhaust system). “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” T. Roosevelt Joe Funderburk, CBO, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC Angie's List Super Award Winner 2018, 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010. Ph: 704-351-1776 www.aohomeinspection.com ![]() |
![]() Quote:
No highrise will allow exterior venting to be retro-fit.
Case closed /rebutal is fruitless. Condo Bob Elliott InterNachi Member of the year 2015 Chicago Chapter MOY award 2015 http://www.chicagopropertyinspection.com/ elliotthomeinspection.com/ www.chicagolandhomeinspection.com www.homeandcondoinspector.com http://www.homeandcondoinspection.com/ http://www.chicagolandhomeinspector.com/ http://www.homeinspectorchicago.com/ http://www.homeinspectorpro.com (Report Software) |
![]() Quote:
As I mentioned in my email and he qoutes here. In the IRC M1503 there is an exception based on manufacturers instructions. ...... your qoute - 'according to best practices' makes more sense now than what I was qouting from the course here. But I already used that qoute which apparently is inaccurate. Basically I will have to be correcting myself to numerous clients. Joe Keresztury JWK Inspections Home Inspections in San Antonio, Schertz, Cibolo, New Braunfels, Boerne and all surrounding South Texas areas www.jwkhomeinspections.com ![]() Last edited by jkeresztury; 2/13/12 at 6:25 PM.. |
![]() Quote:
Rule of basic transportation: you have to fly in a plane to get from Chicago to Miami. Exception 1: you can drive a car if you want to.Commentary: driving is not wrong, but flying may be considered 'better'. It's often just a matter of economics. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” T. Roosevelt Joe Funderburk, CBO, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC Angie's List Super Award Winner 2018, 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010. Ph: 704-351-1776 www.aohomeinspection.com ![]() |
It is not unusual to find co levels of 200PPM at the top of a gas range when the oven is on. I always recommend outside exhaust with a gas range
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
The Importance of Bathroom and Kitchen Fans | mkyriacou | Interior Inspections | 36 | 6/9/13 9:18 PM |
Range hood vent pipe material | jgromkoski | Inspecting HVAC Systems | 72 | 1/1/12 1:02 PM |
Range vent into attic | reldridge | Interior Inspections | 13 | 7/19/11 12:00 PM |
microwave exhaust vent | Scott Schultz | Inspecting HVAC Systems | 24 | 4/28/11 10:31 PM |
Range exhaust hood question | mmorgan | Interior Inspections | 24 | 4/20/06 10:50 PM |
