Old 1/28/13, 1:30 AM
Marc Schrader's Avatar
Marc Schrader Marc Schrader is offline
Default I got shocked by the ceiling...
Okay it wasn't a strong shock, but non the less it was odd. I was feeling a water damaged plaster ceiling, trying to figure out why the ceiling was corroding and rusted. Upon entering the attic I saw some knob and tube coming out of blown in cellulose insulation. The ceiling was damaged from poor flashing around a chimney and therefore water was dripping from the chimney flashing onto the insulation and therefore onto the ceiling below the insulation. Would I be correct to assume that the knob and tube is likely in contact with either the "wet" insulation/ plaster ceiling, therefore energizing the ceiling? What would cause the plaster to rust like this? This house is probably about 100 years old.I got shocked by the ceiling...-328-madison-waterloo-wi-056-jpg
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/28/13, 7:45 AM
James F. McKee's Avatar
James F. McKee James F. McKee is online now
Default Re: I got shocked by the ceiling...
could be metal lathe at the corners.....
Jim McKee
Lorain, Ohio
440 225 8688
www.classicinspector.com
Old 1/28/13, 8:49 AM
Philippe G. Heller's Avatar
Philippe G. Heller Philippe G. Heller is offline
Knob and tube should not be in contact with combustibles. That is why it was isolated with ceramic insulators. It should be called out as a fire hazard.
Rust may be from steel flashing? Sometimes the cellulose darkens water. It may not be rust.
Old 1/28/13, 11:23 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Knob and tube must not be buried in insulation. Period.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 1/28/13, 7:52 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
Nails used to secure lath would be likely source of rust.
Chad Norlen
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 1/28/13, 11:40 PM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
It's probably not just rust, but a combination of deposits picked up by the water as it passed over the brick, mortar, flashing, roofing, old darkened framing, fasteners, lathe and plaster.
As far as the shock is concerned, were you standing on something to reach the ceiling or was it low enough touch? You're probably correct, with old and wet knob and tube there are plenty of scenarios where you could have been in parallel with a circuit and gotten a mild shock. Glad you are still here to tell the story.
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.homeinspectionpeoria.com
Old 1/29/13, 12:36 AM
Thanks for all the input. FYI I did call it out as a safety concern. Next time I'll pull out the old non contact voltage tester before I touch something water damaged....
Old 1/30/13, 6:50 AM
Stephan Tremblay, CMI's Avatar
Stephan Tremblay, CMI Stephan Tremblay, CMI is offline
Certified Master Inspector
Wow, I've never considered this as a shock hazard but will definitely think twice next time! Thanks for sharing!
Old 1/30/13, 10:31 AM
Gary Farnsworth, CMI's Avatar
Gary Farnsworth, CMI Gary Farnsworth, CMI is offline
Certified Master Inspector ®
Anytime I see knob/tube, my electrical inspection is over. Recommend replacement, etc.........
Certified Master Inspector, Retired
Formerly Serving the Greater Kansas City Metro Area
Lifetime InterNACHI Member
"If opportunity doesn't knock, build a door"--Milton Berle
Plaster Ceiling Systems - Hidden Danger Philip LaMachio Interior Inspections 3 12/1/09 8:38 AM
Asbestos ceiling tiles scoslett Interior Inspections 30 10/20/07 2:30 PM
Vaulted Ceiling Insulation rcooke Canadian Home Inspectors 4 1/22/07 12:24 PM
