Old 6/13/17, 5:28 PM
Scott Wells Scott Wells is offline
Default Is it solid hardwood?
Hi All,
I just finished an inspection where the floors appeared to be solid hardwood but there was no real way (that I know of) to tell. For the life of me I couldn't find a floor register or any other area to look at the edge of the boards.
I hate to say it is solid hardwood when it may be engineered hardwood, and for that matter, some laminates these days are really good. I did notice that some of the strips (at thresholds mostly) had been face nailed with finishing nails and patched over with a tiny speck of matching putty. Is that some kind of clue?
Is there any way to tell by looking at the surface?
Thanks!
Scott
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/13/17, 6:10 PM
Thomas Witt's Avatar
Thomas Witt Thomas Witt is offline
Certified Master Inspector ®
Default Re: Is it solid hardwood?
Why does it matter?
Old 6/13/17, 7:07 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
You should be able to distinguish fairly quickly between a hardwood surface (veneered or solid) and a floating laminate floor. That is the only difference I state on planked flooring. Or, you could take core samples...
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 6/13/17, 8:37 PM
Frank Rotte Frank Rotte is offline
Community Guest
Laminate usually uses plastic trim. Wood is wood, except that solid wood can be refinished, whereas engineered has a very thin refinish layer. And that would be the reason to distinguish between the type of wood floor.
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Old 6/13/17, 8:52 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Ya! gotta bite your teeth in it to make sure!
Like a silver or gold coin.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 6/13/17, 9:02 PM
We inspect the floor . If you want to inspect the floor covering that will be up to you.
There is a very big difference between floor covering and the floor...The essence of what is floating the covering is the floor.
Now! If the covering has issues that I don't like I report it.
But, draw the the line between the floor and the floor covering..OK?
There is a difference..Yep!
#1st Pro Inspection
Old 6/13/17, 10:27 PM
Jeffrey R. Jonas's Avatar
That crap advice may work for you in Florida with your "cheaper the better" construction methods, but it would never fly in the real world where we actually value our building materials and 'finishes'.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 6/14/17, 5:30 PM
Thanks All for your feedback!! I appreciate it. I was asked by the buyer, and I was stumped. I offered to take a core sample out (in the middle of the living room) but that didn't go over so well (just kidding!)
Old 6/14/17, 5:47 PM
You are a freakin' joke...
You have been doing it wrong for all these years..Yep!
Poor old decrepit thing ! Don't know the difference between a floor and floor covering!
Are you Blonde?
#1st Pro Inspection
Old 6/17/17, 12:07 PM
Jeff Spencer's Avatar
Jeff Spencer Jeff Spencer is offline
If there is a floor register, pull it out and look at the floor material.
Jeff Spencer
Story County Home Inspections
Ames, Iowa
515-779-6724
jeff@storycountyhomeinspections.com
www.Storycountyhomeinspections.com
Old 6/17/17, 12:10 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Yeap...
Old 6/17/17, 3:04 PM
Les C. Abstein, CMI's Avatar
Les C. Abstein, CMI Les C. Abstein, CMI is online now
The easiest way I know to tell the difference on a slab floor is laminate flooring will have a slight dip where the joints meet. Hardwood floors will be sanded completely smooth.
Old 6/20/17, 12:37 PM
Erik Schmidt Erik Schmidt is offline
If the floor is fairly new there is usually a box with some spare left over pieces stored somewhere. If you have the right tools, you could probably find a short baseboard section that can be carefully pried off and replaced afterwards, not something I would do tho.
I have been fooled with laminate that I thought was hardwood, they are getting pretty clever with texture and patterns, if you don't know and can't determine call it "wood or wood product flooring"
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 6/20/17, 2:12 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
You need a ball bearing to test for the hardness.
Is it solid hardwood?-janka_hardness_test-jpg
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 6/20/17, 6:34 PM
James F. McKee's Avatar
There are plenty of pre-finished hardwood floors these days that come with an eased edge....
Jim McKee
Lorain, Ohio
440 225 8688
www.classicinspector.com
