Old 5/31/18, 12:18 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Trapped moisture
Trapped moisture-100_5555-jpg
2005 build
Walk out basement
Poured foundation
House wrap behind vinyl siding over OSB
Unfinished basement walls
Trapped moisture behind vapor barrier on all but poured foundation portions.
Fiberglass batt insulation.
OSB not affected yet where checked
Minor organic growth. No odors.
I usually recommend removal of vapor barrier to let it breathe and dry out completely along with the use of AC and dehumidifier.
Any other views on this issue?
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/31/18, 12:38 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Trapped moisture
Why did it get wet in the first place?
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 5/31/18, 3:00 PM
Apparent condensation. It does that up here. Moist air cool basement. Seen it many times.
Owner stated she seldom uses the AC and no de-humidifier present.
We no longer build way this because this happens. We use blue or pink board instead.
Michael Larson
Hudson, WI
Call me
Old 5/31/18, 3:20 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Originally Posted by mlarson View Post
Attachment 201952
2005 build
Yes, I agree. I'd definitely recommend to remove it and dry it out, and not reinstall it.
Is this area below ground? With your description I'm thinking not.
Old 5/31/18, 3:25 PM
Its a walk out basement. The areas not exposed had no moisture behind the plastic.
I usually just tell them to remove the plastic or slit it and let it breathe.
The sad thing is that the vapor barrier was required when built. I've seen too many with rotted OSB as a result.
Michael Larson
Hudson, WI
Call me
Old 5/31/18, 6:04 PM
Dennis DiVito Dennis DiVito is offline
What would the walls be like if the interior sides were finished with drywall? How would you inspect that with knowing what you described as typical condensation issues in your region?
Just curious
Old 5/31/18, 6:18 PM
Originally Posted by ddivito View Post
What would the walls be like if the interior side were finished with drywall? How would you inspect that with knowing what you described as typical condensation issues in your region?
Just curious
You can't.
It's better if finished but once moisture gets in it's like Hotel California.
Michael Larson
Hudson, WI
Call me
Old 5/31/18, 7:21 PM
Besides all the rest of the comments... It does need to dry out..Yep!
#1st Pro Inspection
Old 6/4/18, 11:17 AM
Erik Schmidt Erik Schmidt is offline
That's interesting, vapor barrier should be on the warm side, so what side is that in Wisconsin in June and then December? I suppose I would recommend replacing batts with board, easy to do as basement is not finished and is proven to work in new builds.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 6/4/18, 4:12 PM
That's how it's done on more recent builds.
Michael Larson
Hudson, WI
Call me
Old 6/4/18, 10:23 PM
James E. Braun, CMI's Avatar
Get rid of the vapor barrier, so the moisture can more through the wall. In Missouri, we are starting not to put vapor barriers on the inside because of that reason.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 6/4/18, 10:43 PM
That was my recommendation.
Michael Larson
Hudson, WI
Call me
Old 7/17/18, 3:05 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
I'm confused.
So, moist air from the interior moves outward toward the exterior through the insulation and OSB and then meets the vapor barrier which is cooler than the interior because it is colder outside than inside? That's why warm, moist air is condensing on the membrane? Because it's colder outside?
The housewrap is the vapor barrier you're referring to... right? why do we see plastic on the interior of the wall with wet insulation behind it? You said the vapor barrier was between the siding and the OSB ext. wall sheathing, so it shouldn't be visible. I'm totally lost here.
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Old 7/17/18, 7:54 AM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is offline
So very sorry, Michael.
After reading your post,
2005 build
Walk out basement
Poured foundation
the image appeared to me to be efflorescence on concrete. Damn. My eyes are going. So sorry.
Kenton brought me back to the thread with his reply and I concur.
If you could, or feel like it, could you describe the wall assembly once more please. Looking forward to your answer.
Robert Young's ​Montreal Home Inspection Services Inc.
Home Inspections & Building Inspection Services.
Covering on and off islands in greater Montreal and Laval. (514) 489-1887 or (514) 441-3732.
Our Motto: Putting Information Where You Need It Most, "In Your Hands."
https://montreal-home-inspection-services.com
Old 7/17/18, 8:10 AM
2005 build
Walk out basement
Poured foundation
Requires anti damp at the very least.
House wrap behind vinyl siding over OSB. House wrap should be of a Vapor Diffusion Retarder type.
. The interior Vapour Barrier. thin mill plastic, is leading to an increase in moisture related problems. Remove the plastic vapour barrier.
Fiberglass batt insulation. No issue when there is circulation.
OSB not affected yet where checked. Good.
. No odors. Microbial growth can/may be a concern.
