Old 3/14/19, 2:46 PM
Terrill Ewald Terrill Ewald is online now
Default What type of garage ceiling is this?
Home built in 1965. There is rebar inside the cemented areas, but they look like some type of concrete blocks. Just curious, first time seeing this.
What type of garage ceiling is this?-p3140204-jpg   What type of garage ceiling is this?-p3140207-jpg   What type of garage ceiling is this?-p3140208-jpg
Terry Ewald
Advanced Pro Inspections
Potomac, Maryland
www.advancedproinspections.com
Serving Maryland, Virginia, and the District of Columbia
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/14/19, 5:58 PM
Dennis DiVito Dennis DiVito is online now
Default Re: What type of garage ceiling is this?
What was above this ceiling? It does look like block, but I can not tell
Old 3/14/19, 6:01 PM
It was a builtup/tarred roof under the rooftop porch
What type of garage ceiling is this?-dsc02167-jpg   What type of garage ceiling is this?-p3140392-jpg
Terry Ewald
Potomac, Maryland
Old 3/14/19, 10:46 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
I've seen that type of flooring used at the Boldt castle in NY 1000 Islands during a tour. The castle was built in 1900. Its a concrete block flooring system.
On The Level Inspection
Gatineau, Québec
Old 3/16/19, 5:20 AM
Paul Lesieur, CMI's Avatar
Paul Lesieur, CMI Paul Lesieur, CMI is online now
Its a formed and poured slab/ ceiling. You install supports, install decking, tie rebar in a certain pattern, place concrete, finish the surface, remove the forms and supports, install roofing, go home.
Tags
type, concrete, blocks, time, curious
