Old 9/13/18, 5:17 PM
Brandon Bair Brandon Bair is offline
Default Water Damaged Ceiling
I recently inspected a property that appeared to have water damage along the ceiling and down a wall. Directly above is a full bath and as I was concerned with ongoing moisture issues, I used a surface (not probe) moisture meter in this area to make a final judgement. In doing so, part of the ceiling crumbled before I even got close to it. As you can see in the picture, the corner is cracked and damage is visible down the wall. The seller is irate and wants me to pay for the drywall repair. I explained that there was preexisting damage and I don't feel responsible for the repair. What are your thoughts?
Water Damaged Ceiling-img_9359-jpg
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/13/18, 5:23 PM
Joshua L. Frederick Joshua L. Frederick is online now
Default Re: Water Damaged Ceiling
Originally Posted by bbair View Post
I recently inspected a property that appeared to have water damage along the ceiling and down a wall. Directly above is a full bath and as I was concerned with ongoing moisture issues, I used a surface (not probe) moisture meter in this area to make a final judgement. In doing so, part of the ceiling crumbled before I even got close to it. As you can see in the picture, the corner is cracked and damage is visible down the wall. The seller is irate and wants me to pay for the repair. I explained that there was preexisting damage and I don't feel responsible for the repair. What are your thoughts?
Pay for what repair? The leak?
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 9/13/18, 5:25 PM
Repair of the drywall.
Old 9/13/18, 5:26 PM
What about what caused it? Can they access from above to fix?
Old 9/13/18, 5:28 PM
Regardless, who cares what the seller says. That was not cause by a moisture meter.
Old 9/13/18, 5:32 PM
I was told that the previous plumbing leak was addressed. The drywall was loose and barely hanging there to begin with.
Old 9/13/18, 6:51 PM
Charley L. Bottger's Avatar
The wall is also cracked from past moisture the whole mess should have been repaired at the time of the leak. I would not pay for anything.
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 9/13/18, 7:40 PM
Roy D. Cooke, Sr's Avatar
Not you fault ,You found it recorded it and reported it and wrote it up . Not your client , Talk soft and move on.
Old 9/13/18, 10:06 PM
Chuck Evans's Avatar
Certified Master Inspector ®
No way, no how. That was severe latent damage that should have already been corrected. Sheetrock is supposed to have greater integrity than toilet paper. You found a defect. I'm sure it extends well past the area of complete failure. Document it as such.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 9/14/18, 8:54 AM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
I'm sorry, I do not have a magic wand that I waived across your ceiling to cause damage AND create the water stains.
I am happy I discovered the damage for my client!
Walk away! It's soooooooo stupid I would not even return another call from him.
**note: possible hidden damage may exist.
http://www.alltropic.com
Old 9/14/18, 11:18 AM
Thank you all!
