Old 2/17/19, 10:46 PM
James S. Saunders's Avatar
James S. Saunders James S. Saunders is offline
Default What is this?
I saw this cracking on the inside of 2 windows in the home today. Can someone tell me what this is on the inside edge of the window that is cracking and how should I report it if it is reportable? Thanks
What is this?-unadjustednonraw_thumb_2fd-jpg   What is this?-unadjustednonraw_thumb_300-jpg
James Saunders III, CPI
Certified Inspectors of North Carolina LLC
President/Member
910-578-4943
www.certinspectnc.com
james@certinspectnc.com
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/18/19, 5:13 AM
Michael Bitterman, CMI HI7792's Avatar
Michael Bitterman, CMI HI7792 Michael Bitterman, CMI HI7792 is online now
Default Re: What is this?
Those appear to be double pane windows. Can't tell if 2 panes of glass are there but I would say either there is only one and someone has filled the void with a putty that is cracking or the seal between the panes of glass is cracking. Either way it should be noted.
Mike Bitterman CMI
SNS Home Inspections LLC
Serving all of Central Florida
http://www.snsinspections.com
Old 2/18/19, 4:40 PM
Brian E. Kelly's Avatar
Deteriorated Swiggle Seal. Call it out. They do not use that material anymore because it fails prematurely.
Old 2/18/19, 8:02 PM
Thank you so much for your response. I thought that it might be a seal but wasnt sure. Thanks so much.
President/Member
910-578-4943
Old 2/18/19, 11:15 PM
Joe Funderburk, CMI's Avatar
Certified Master Inspector
What should he say? Seal MAY fail therefore the glass should be replaced? What if the window is 10 years old and hasn't failed yet?
T. Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2018, 2017, 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Old 2/19/19, 2:31 PM
That window is over ten yrs old.
That is one of these things Joe if you do not call it out you have a good chance of getting a call back.
That swiggle is done, probably a window facing south. That material is no longer used because that is what happens to it. Cheap contractor windows not worth worrying about if it was my house.
But if you do not mention it, the client may complain at a latter date.
I just say "..deteriorated window seals...bla bla bla window contractor"...
But I would hang blinds on that window.
Old 2/19/19, 3:11 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Are you referring to these cracks?
Are they on the interior of the window?
It looks like trim of some sort outside of the window..
What is this?-nachi-jpg
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 2/19/19, 8:34 PM
That is why I questioned whether there was 2 panes of glass
Mike Bitterman CMI
Old 2/20/19, 1:44 AM
Junior S. Fudge's Avatar
Junior S. Fudge Junior S. Fudge is online now
Look at photo #2 again. You can see light reflecting of the wall & inside glass pane as well.
Old 2/20/19, 1:54 AM
Chuck Evans's Avatar
I see them frequently with some brands of double pane windows. I've never noticed any correlation between cracks in the spacer and loss of the thermal seal or fogging of the glass. I don't get excited over them.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 2/20/19, 4:38 AM
Yes you are right. Good catch. Strange that the seal looks like that and the window looks clear of fogging and condensation.
Mike Bitterman CMI
Old 2/20/19, 11:21 AM
The plastic spacer can't handle the thermal expansion/contraction, and develops stress cracks. The window seal itself can fail eventually. If there's no condensation so far, the seal is still doing its job.
Old 2/20/19, 11:35 AM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
I was told that thermo panes are not sealed units; if they were they would explode when the sun comes out. They use desiccant to absorb moisture and when it is no longer effective the glass panes fogs.
On The Level Inspection
Gatineau, Québec
Old 2/20/19, 11:59 AM
I don't call it out unless the seal has totally failed and the glass is fogged or there is bulging that is also an aesthetic issue (black seals that expand into the glazing area which indicates imminent failure). We are taught in our State to allow for normal wear and tear. If the window is "functioning as intended" (not fogged and opens and closes) it's good enough for me. Nothing lasts forever but a window that has simply cracked seals that still function is not a good reason to write it up for me.
BTW, I disclaim being able to find all failed seals anyway as climate conditions can affect their discovery.
T. Roosevelt
Ph: 704-351-1776
Tags
inside, cracking, window, reportable, report
